Stahlwerks.com
912-6 gets a new pan
Last week I was under the 912-6 installing the new fuel line and figured I would fix a small hole in the pan while I was down there. Did some poking around, and one thing leads to another...
Pretty ugly. I got new pans from Restoration design, and already have the old one out. I've got a few custom patches to make also, figure I'll bend some 5/8" flanges on some stock for a start at the office. Here's my question. The panels I cut out have a reinforcing stamping over the suspension mounting points... ... but the restoration design parts do not have it.... Do I need to remove the old ones and install them on on the new pans? BTW, after all crappy patch panels I've seen over the years working on vw's, these from Restoration Design are incredible, clean laser cut edges, sharp bends, great spot welds. Man I wish they would make vw patchs. TIA
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Senior Member
John,
Do they have a website? Would like to see what all they make! Thanks, JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Stahlwerks.com
Senior Member
Thanks, never heard of them!
Joe
John, call Bill at RD, he has the reinforcements you are looking for, and they fit too.
Damon @ SERIES 900.com Sunapee NH several 911 variants |
If these guys would make metal flares for STs, etc., they'd probably get good business from Pelicanites.
'74 Euro Carrera * '64 356SC Coupe |
I would rather be driving
They do make flares. Just not the ST version. The problem is that the tooling is quite expensive to produce quality parts. He has suggestions for many new parts already.
Bill does a great job and provides high quality parts. I have several on both of my cars.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Yup, agree, Bill at Restoration Design is great, I bought panels from them for a 69 and a 74 and they look like original panels, every little detail is copied from original and they fit great.
Derek
1989 964 Carrera 4 Coupe |
funny how RD's rockers are imperceptible from dansk though....
Stahlwerks.com
The reinforcements are on the way. Pan fitted up well tonight, just have a few notches to cut for the washer pump and the valance bolts. I'll have it this weekend probably.
Mittelmotor
did a quick look last night at mittelmotor, what do you know about them?
Stahlwerks.com
This is really being a pain, the alignment of the pan is off by like 10mm's. I'm thinking the front end got wacked at some point, gonna try and measure from the rear suspension points to the front beam in the morning, make sure it is straight. Grrrrr.....
Stahlwerks.com
Update. My alignment issue was solved, the bolt inserts on the new pan are off just a hair, won't cause any alignment issues.
Got the pan tacked in place today, just some welding and small patches to go, then the tank support. Sure looks better with new metal
