bose213's Avatar
Knocking sound at low rpm (video attached)
Hello everyone. I have Porsche 911sc 1979 sportomatic.
I’ve noticed a knocking sound coming from my engine when the RPMs are low. It doesn’t seem to happen at higher speeds, but at revs, the noise is quite noticeable.
Does anyone have an idea of what could be causing this?
Here’s a link to a video where you can hear the sound:
[https://youtu.be/zuZhG0kmnw8?si=afWaFWJs27MMgn60]
Thanks in advance for any help!
Old 03-31-2025, 04:10 PM
walt's Avatar
Did this develop suddenly? It does sound like a valve adjustment is needed. Many threads on this subject. Also, when you pull the covers make sure all the rocker arm shafts are fully engaged.
Walt
82SC 3.0
81SC 3.6
Old 03-31-2025, 04:21 PM
tobluforu's Avatar
Vid is too short, hard to tell. But be careful cause if it's a chain tensioner, all hell can break loose.
Old 03-31-2025, 06:08 PM
proporsche's Avatar
it is not the valve adjustment, it is not the chain tensioner,
You should drain the oil and see if there is any debris on the drain plug .
Also more info would help...the rpm is too low-why ....and also sounds like a rod noise..
Do you hear it when cold only or hot as well?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-01-2025, 12:15 AM
Ivan
^^This. Way too solid/beefy/low pitch for a valve issue. It's a solid sound that would lead me to rod, loose flywheel, or something much larger/solid.
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 04-01-2025, 10:03 AM
Still here
pmax's Avatar
I wouldn't drive that anymore.
Crank it by hand, check if there's a similar sound.
Remove the bumper if you need to.
Old 04-01-2025, 11:14 AM
