cantdrv55's Avatar
smog pump for CA cars
Does anyone know if a smog pump from a '75 will fit a '79SC? Mine is binding and shredding belts. Is the smog pump pulley supposed to turn with little resistance? When I turn mine by hand, it's smooth for a couple of turns then binds a half or so turn then smoothens out again. Is that normal?
Old 03-07-2004, 10:43 AM
'75 ----- 911.113.111.01 air pump w/pulley
'76-'79 - 911.113.111.03 air pump W/O pulley
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2004, 01:41 PM
cantdrv55's Avatar
Thanks Ronin.
Old 03-07-2004, 02:31 PM
RETIRED
Joe Bob's Avatar
I have one here that came off my 3.0....make me an offer.
2012 ML350 3.0 Turbo Diesel
Old 03-07-2004, 04:15 PM
vash's Avatar
you can still drive the car without a smog pump right? i mean while the belt is shredded and you are in the process of getting one.
poof! gone
Old 03-07-2004, 05:36 PM
cantdrv55's Avatar
I've read mixed comments about driving the car with the belt off. I don't know for sure. If someone knows the answer, please chime in.
Old 03-07-2004, 05:43 PM
Cool
generally it's OK to drive the car with the pump disconnected.
the only issue I have ever read about is that if you have Thermal Reactors.. then the added pump airflow will keep the Thermal Reactors, thus the heads, cooler.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2004, 06:25 PM
RETIRED
Joe Bob's Avatar
Ran mime w/o it for years....it's been sitting on a shelf. Now that I have a 3.6 don't need it....
Old 03-07-2004, 06:30 PM
Cool
ditto..
but I had the 3 in 1 tubes instead of the reactors.. it was a real constipated exhaust flow.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2004, 06:33 PM
Go ahead and take the whole thing off, it won't hurt a thing and will only give you more room and less weight. I have 2, one for the 2.7 and one for the 3.2, both look and fit the same and are only used once every two years (smog). Personally I think the car goes faster without it on but it could be several other things.
Old 03-07-2004, 07:43 PM
Hilbilly Deluxe
emcon5's Avatar
You will need it to pass the visual portion of the California smog check.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-07-2004, 07:47 PM
RETIRED
Joe Bob's Avatar
My SC was a euro model that was Federalized when it came over....all US SCs in 83 did not have a pump....mine did. It has a 930 part #.....
Old 03-07-2004, 07:50 PM
I just passed CA smog by installing the smog pump and well that's it. Car has backdated exhaust (74) and no cat. conv.
Old 03-07-2004, 08:00 PM
Not as it seems
juanbenae's Avatar
what state novice?
Old 03-08-2004, 01:25 PM
ca
Old 03-08-2004, 02:04 PM
Not as it seems
juanbenae's Avatar
county? was it the dyno roller test? did they ask about the cat not being on it? or were the heat exchangers mistaken? i have heard that a numb tech may mistake the exchangers for a cat.
Old 03-08-2004, 03:17 PM
