-   -   New front end! (http://forums.pelicanparts.com/porsche-911-technical-forum/152346-new-front-end.html)
thrown_hammer 03-08-2004 02:58 AM
New front end!
Thanks to Jerry for dropping off the new front end. These are GT Racing peices. I was a little worried about that. They fit very well and seem to be built very well. I need to start the fitting process tonight. (if it quits snowing.) Anyhoo here is a pic.
http://forums.pelicanparts.com/uploa...1078747106.jpg
trj911 03-08-2004 04:48 AM
Shawn, your project looks good! Are you still hoping to be done next month?
thrown_hammer 03-08-2004 05:11 AM
I hope to. But I won't sacrifice quality just to hit the deadline. I have many nights of "fitting" ahead of me. I think it's doable. We shall see. The tub needs a little wet sanding and its ready to shoot. The front end obviously will take some time. Also when i took out the sunroof it quickly became obvious why it never worked very well. Little pieces came out from everywhere. I may just weld it shut and pull all the motor and cables.
Rot 911 03-08-2004 05:14 AM
Wow you are going to have to starting adding weight if you hope to keep that lightweight on the ground!
thrown_hammer 03-08-2004 05:22 AM
I plan on throwing about 230 pounds in the drivers seat!
Shuie 03-08-2004 05:25 AM
Nice work Shawn! Did you weight the glass and steel parts by any chance?
Kevin Stewart 03-08-2004 07:27 AM
Hey Shawn that rocks, cant wait to see the finished project, anyway thanks for all your help the other day, Kevin
sammyg2 03-08-2004 07:29 AM
When do you plan to drill all the little holes in that fiberglass for aerodynamics?
thrown_hammer 03-08-2004 07:32 AM
No problem Kevin. It's what we do. Besides enough people have helped me out I feel compelled!
Sam,
I plan at least two holes. One for each hoodpin. :D
Shaun @ Tru6 03-08-2004 07:35 AM
Looks great Shawn, any more pics? How are you fastening the fenders to the rails? Anything in between the glass and metal?
thrown_hammer 03-08-2004 07:40 AM
Shaun,
I am using 1/4" bolts with fender washers. I have some Wurth fender putty for the joint. I shot that pic on the way out the door this AM. They are just hanging there. I haven't done any fitting yet. The fenders actually have little dimples where the holes will go. We will see how close they are once I get them trimmed out.
Randy Webb 03-08-2004 09:51 AM
Shuie,
weight of the glass and steel parts -- Jim Calzia has very accurate wts. on his web page at the Early 911 site.
thrown_hammer 03-08-2004 09:55 AM
According to Jim's site I saved Approx. 45 pounds.
thrown_hammer 03-09-2004 03:09 AM
Here is the hood fitted. Check the gap and see what you think. I also need to add some shims to bring the hood up to line up with the cowl. Do I need the hood gasket in when I fit the fenders?
http://forums.pelicanparts.com/uploa...1078834165.jpg
http://forums.pelicanparts.com/uploa...1078834174.jpg
http://forums.pelicanparts.com/uploa...1078834183.jpg
jstgermaine 03-09-2004 04:18 AM
Looking good Shawn!! I am glad they are fitting as well as we thought they would.
By the way, on an earlier thread, Shawn was pretty happy with his new exhaust sound...as I promised him, here is the file..it's in mpeg format and about 2.8mb.
Please don't stream from the server (it's pretty full), right click and save target as...
I LOVE THIS SOUND.
The Hammer's Music
(edited for file size change)
thrown_hammer 03-09-2004 04:23 AM
Jerry,
I right clicked and save as but i cant get the file. The supense is killin' me!
Shaun @ Tru6 03-09-2004 04:27 AM
I right clicked, save as and WOW. sounds fantastic. Shawn, what do you have for a motor in this thing? Also, what oil cooler are you using up front?
Jerry, if you strip out the video by saving as a sound file only (if using QuickTime) you will have a much smaller file, which means a lot long sound bite!
jstgermaine 03-09-2004 04:28 AM
Hmmm...I just tried it and it works fine here....:confused:
Shawn, try streaming once.....please Shawn only.
If that doesn't work, do you have a high speed/cable/T1 at work?
I could email the file to you. It's only 2.8mb, but your hotmail account will bounce it.
thrown_hammer 03-09-2004 04:32 AM
Shaun,
I have a stock 3.2 with headers and that sport muffler. I am using a fender mount Mocal cooler.
Jerry,
I will PM you my work e-mail that should let a large file thru.
jstgermaine 03-09-2004 05:47 AM
That's actually my plan, but I just lost my video driver on the main system...gotta put her under the knife before I can edit it for the masses.
I absolutley hate having to switch to inferior systems to work......:mad:
