alternator warning light...Loose fan belt(?)
Recently rebuilt my alternator on 70T but the light still comes on at idle but goes out at higher RPMS.
I suspect my fan belt is loose. where do I place the shims to tighten it? thanks. |
how much fan belt play ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
i dont know how much play, have to check tomorrow. i just need to look at the easy things first to sucessfully diagnose this problem
the red lite warning at idle was pretty routine for those early 911s. there are solutions after you confirm a good charging system
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I had the same trouble, seemed like the belt was fairly tight and had gone to a newer alternator version with internal regulator.
Result: Added another shim (6) shims total. Pain to get on but did the trick. I would clean up the ground bolt and the copper leads on the body by the battery. That cured a problem I had that I was blamming on the switch
67 Normale "Old Rusty" 67 Rennen inspired 73 ST Caged Beast RGruppe #383 |
Rick, how did you arrange the 6 shims? some could go on the inside , some on the outside. please explain |
i think if your belt was loose, your light would come on occasionally at above idle engine speeds. but it wouldnt hurt as the first check.
poof! gone |
