-   -   Where can I purchase a Yellow 5A fuse? (http://forums.pelicanparts.com/porsche-911-technical-forum/152505-where-can-i-purchase-yellow-5a-fuse.html)
falcon 03-08-2004 05:36 PM
I purchased a kit for spare trunk fuses for my 88 cab but the red is 16A, the blue is 25A and the white is 8A. I need a yellow rated at 5A. I've looked at various websites with no luck.
Any help appreciated.
Randall
AFJuvat 03-08-2004 06:12 PM
You can use an 8 amp temporarily.
Some auto parts stores have them - I think even Wal-Mart even carries an assortment of "german" fuses.. Failing that, I would suggest a Porsche, or VW dealer.
AFJuvat
47silver 03-08-2004 06:54 PM
try this
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_electr_pg10.htm#item42
84porsche 03-08-2004 07:26 PM
It took me a long time and several auto parts stores to find these but here is the best place I have found with very reasonable prices and excellent services. They will ship to you I believe.
Yorba Linda Auto Parts
4981 Valley View Avenue
Yorba Linda, CA 92886
(714) 528-2450
Jim Sims 03-08-2004 07:34 PM
Do not use an 8 amp fuse; an 8 amp fuse doesn't blow until the power has reached 250% more than what a 5 amp fuse will pass! Doing this could melt the circuit and do significant damage to the adjacent wirng in the harness. The yellow 5 amp fuses are PN 90017300690 and are available special order through Pelican for $1.00 each. The 5 amp yellow fuses are becoming difficult to find in auto parts stores. Type in the part number in the "Search Pelican Parts" box. Jim
falcon 03-08-2004 08:52 PM
thanks guys for the info.
It is listed in Pelican for a buck apiece.
3.2 CAB 03-09-2004 05:44 AM
I was in a local stop-and-rob, just happen to walk by the auto supply section... couple of different types of generic oil, additives, light bulbs, and the usual other crap. I then noticed they had a display of "import fuses" next to the domestic fuses. The packages had 2 of each rating... 0.99 a pack, of course I bought all of the packs they had. I now have a lifetime supply of all the fuses I would ever need. Could not believe it. I find myself looking at the "auto supply section" in all of these corner stores when I am in them now to see if they might have any other goodies.
