-   -   Is there CV rebuild tech article? (http://forums.pelicanparts.com/porsche-911-technical-forum/152596-there-cv-rebuild-tech-article.html)
chrisp 03-09-2004 09:22 AM
I want to disassemble and inspect my CV's before I go out and buy new ones. My car has 125k miles and original CV's (date code is 03/82).
Is there a tech article somewhere? I didn't see one on the host site and searching within the BBS is tough because you cannot search by "CV" so I tried joint, constant, etc.
I am mostly concerned about orientation of parts, grease apcking methods, and reassembly tricks.
Thanks.
KTL 03-09-2004 09:33 AM
Here's a good place to start:
http://forums.pelicanparts.com/porsche-911-technical-forum/142879-cv-joints.html
When you get to the last post by Warren/Early_S_Man, make sure to use his links! Those pages he posted from an older Bentley manual are perfect.
edit:
Try some different search terms because I know i've replied to alot of topics about the CV joint subject.
Gunter 03-09-2004 10:04 AM
Try a search on all forums with: CVjoints, no space between CV and joints.
