Pompatible ignition wires
I have a 79 911SC. I just bought some ignition wires and am not sure they are compatible. I bought a set called Fyrebraid. When I got them I saw that they do not have the external braided wiring that the stock wires have. Can I still use these wires? Does anyone have experience with these wires or should I stick with the original steel braided wires?
Cheers, Elliot
Old 01-31-2005, 12:54 PM
Friend of Warren
You don't need the external wire braiding. Those should work just fine.
Kurt V
Old 01-31-2005, 12:56 PM
Slant930's Avatar
Pompatible? I thought maybe you had some wires that were stuck up or had an attitude, i.e. pompus. But I see you meant compatible. Sorry, just had to chuckle some, mostly at myself.
But to answer your question, as Kurt points out, wires without the braiding will work just fine.
Tim
1983 930 w/ goodies
Old 01-31-2005, 01:14 PM
