-   -   adding a return line... (http://forums.pelicanparts.com/porsche-911-technical-forum/153030-adding-return-line.html)
atlporsche 03-11-2004 05:17 PM
as most of you know I'm building "mutt".
I need to run a fuel return line from the FPR to the fuel tank...do you think I can just run it up to the vent and in that way? I don't think it'll hurt anything...but I'm not really sure, so I'm asking.
sjd
slater 03-12-2004 11:03 AM
What exactly are you building? I have a 912 with a 2.7 and I ran the return line from the engine into a hole in the tunnell in front of the tranny, then used a snake to get the line through the tunnell and out the hole in the bottom of the cubby in the trunk. It turned out pretty nice.
atlporsche 03-12-2004 07:59 PM
subaru powered 912. flat fours are cool...esp the turbo ones.
I need to run a line back into the fuel tank. if you have a part number for the piece that goes in the other bung, or if you just used another fuel pickup...
I can get the line from front to back okay...just need an idea or three to actually put it into the tank.
I thought about running into the vent hose area.
