Kolibri
Rebush Zeniths?
Both the throttle shafts on my Zeniths wiggle easily back and forth to where you can spray carb cleaner at the bush and see it instatnly at the shaft nut!!
I am thinking about buying some rebushed Zeniths from a member on the forum. My question is, is there a company that does this for these carbs, or is it a local machinist? Getting hard to find good set of any used carbs anymore. Thanks in advance.
1942 VW Kübelwagen 1940 Zündapp KS 600 1941 Zündapp KS 750 1975 Volvo C303 TGBII 1967 Honda S90, 1975 CB550 |
I spoke to my local machinist about this before I bought my own mill, he said it would be a very easy task. Basically he would open up the shaft bores, press in new bushing material and then hone it down to the proper size. Mine only leak a tiny bit so I'm putting it of until I do a full rebuild.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
