Randy Webb's Avatar
clutch job on 901
Besides the discs, what should be replaced when doing a clutch job on a 901 transmission?
the TO bearing for sure, but what else?
- what about those little plastic tabs or whateveron the sides of the TO bearing?
- anything else?
thx!
Old 03-09-2004, 10:02 PM
Jim Smolka's Avatar
Clutch disk
Pressure Plate
TO bearing
Platic Tabs.
Little fork looking piece that holds the shift fork to the pivot ball
Flywheel bolts & 'special washer plate'
Main seal
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-10-2004, 12:56 AM
Jim Smolka's Avatar
Here are some PP pictures:
[img]http://forums.pelicanparts.com/uploads2/914_clutch_equipment1078909091.jpg[/img]
[img]http://forums.pelicanparts.com/uploads2/914_flywheel_seal1078909111.jpg[/img]
'81 SC 3.6 (Beast)
Old 03-10-2004, 12:58 AM
Series900's Avatar
the pivot ball stud itself, sux when that breaks after years
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 03-10-2004, 04:47 AM
SteveF_911's Avatar
Pull the engine and gearbox out and then look at the damage.
The through-out bearing on the 901 is a real solid item and may not need replacing.
Measure the clutch plate for wear and check for cracks in the metal plate.
Measure the wear on the flywheel and check the presure plate.
Replace what needs to be replaced.
When I uped the power output of my engine I had a slipping clutch all that was required was more clamping presure from the presure plate.
This was only a 2-3 hour job to replace a presure plate in a early 911.
66 911 with S engine
2008 Westfield XTR2
Old 03-10-2004, 07:23 PM
Randy Webb's Avatar
"the pivot ball stud itself, sux when that breaks after years"
- is that what PET calls "bush" M 8x9 #999-504-040-02
or "threaded bush" # 999-504-025-01??
Or is it some thing else?
And is the "Little fork looking piece that holds the shift fork to the pivot ball" the thing that PET calls the "retaining plate" # 901-116-077-01?
Thanks!
Old 03-10-2004, 09:01 PM
Randy Webb's Avatar
C'mon -- I know you guys woul drather answer this than work -- esp. on a Friday morning....
Old 03-11-2004, 10:05 PM
Series900's Avatar
uhmm at 2:40 amEST I am the early bird aye? I did not look into pet yesterday, but yes those 3 parts are good to replace, JW may have more words of wisdom. I have seen the ball pin snap, the nylon cup wear out completly and the fork retainer nut seperate from the fork.
Sunapee NH
Old 03-11-2004, 11:46 PM
Randy Webb's Avatar
IT's a 1968 model year trans -- does the ball pin come out?
Old 03-12-2004, 12:21 PM
Series900's Avatar
it's threaded into the case from what I remember...
Sunapee NH
Old 03-12-2004, 12:55 PM
