Rocker Panel Rubber....Help
I am putting my 74 Targa back together after a paint job. I put the rocker panels back on and I am having a difficult time getting the rubber molding back on. What's the magic technique to getting them on? When I try sliding them on from one end, the lower lip always comes out.
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
Super Moderator
I put a bit of soapy water on mine... Then bend the strip backwards (more than 90 deg.) and push it on...
Worked for me, YMMV
To elaborate on Chris' suggestion. When you bend the rubber back, the lips spread further apart which allows easier engagement with the rocker panel. You don't have to slide it on from one end. Just start from one end, spread the rubber and push into place. Soapy water works as does silicone spray. I would also use stainless steel rocker panel screws to reduce corrosion formation.
It's also described in the factory repair manual. Sherwood |
I have found that a little liquid soap (sans water) works great. I use it as a libricant anytime I am trying to slip something rubber over metal.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
