sunroof not working
My sunroof on my 1980 911SC will only open about 1 inch. It will close back fine. I asume it is a cable (I have Wayne's book), but what side do I need to replace?
Thank you.
Old 07-21-2004, 01:18 PM
When the cables are bad you'll hear a noise like gears grinding as the drive gear skips over the cable.
Old 07-21-2004, 02:14 PM
never ending projects
niner11's Avatar
You might need to take the headliner portion of the sunroof down to get a better look at the cable and lifting mechanism. Mine would jam (82SC) while being opened because one of the plastic lifting pieces had broken. I replaced the cable on one side with an updated one from Pelican. (the updated one is all that is available and needs to be ground a bit with a dremel to fit correctly) In terms of Porsche fixes, this is pretty much a bargain but takes a little patience. Good luck, Chuck
Old 07-21-2004, 02:23 PM
Designer King
Paulporsche's Avatar
Several areas to check:
the cables
A small drive gear inside the gearbox
the rubber clutch
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-21-2004, 03:11 PM
Thank you for all of the help. I ordered the cables fron pelican. Wish me luck!
Old 07-22-2004, 11:09 AM
