-   -   How not to remove a fender (lessons learned, and a question) (http://forums.pelicanparts.com/porsche-911-technical-forum/153289-how-not-remove-fender-lessons-learned-question.html)
djmcmath 03-13-2004 10:25 AM
I'm in process of removing the fenders from my '86 Carrera for the purpose of rust-hunting. Here's my list of "Dan is smarter now than he was before" items:
1.The Bentley's says “may.” They mean “will.”
2.The Bentley's says there are 10 screws inside the trunk. If you only remove 8, you will find that the fender doesn't budge, no matter how hard you pull on it.
3.The Bentley's says that there are also 6 screws along the rear edge of the fender. See #2.
4.Beer is always a good thing, in moderation. It is best to attempt your first fender removal late on a Friday night after your room-mate has drunk himself into oblivion and you're bored.
5.Flexible oil lines aren't, especially if you ignore the line in the Bentley's where it says to unscrew the brackets.
6.Road gunk is nasty stuff.
7.Undercoating is pretty durable stuff.
8.Road gunk, undercoating, and years of mild corrosion make bolts inside wheel wells almost impossible to remove. If you're trying to round out the bolts, you'll have the best success by using the wrong size of socket. The correct size seems to be 10mm, so using an 11mm because the road gunk confused you is an excellent choice.
9.Do not be daunted by the undercoating. Scrape at it wantonly with a screwdriver – do not scrape carefully, because by this point you will be frustrated. You may or may not be more patient if you paid any attention to #4. If you are as fortunate as I was, you'll be able to add blood to the underside of your fender, in addition to the road gunk. If you paid as much attention as I did to #4, you may not feel the missing fingernail for a moment.
<sigh> So now I'm at a standstill. I can't figure out how to get on the uppermost bolt from behind the oil lines inside the fenderwell. It's covered in that rubbery undercoating. Moreover, the rubbery undercoating is effectively bonding the fender to the frame, and I don't know how to separate them without damaging the fender. I hunted through the archives and couldn't find anything definitive. Has anybody ever found a solvent that works on that stuff? Any hints on getting to the bolt behind the oil lines?
TIA,
Dan
steand 03-13-2004 11:08 AM
In My experience, you need too remove the undercoating around all screws/bolts/nut's. Use a large screwdriver as scraper evt. a cup brush on the grinder (wear googles). You can use a putty knife to cut the undercoating along the seems, and lift it up from the bodywork.
It's dirty work.
If everything else fails. The undercoating is solvable in Petrol, i used it and a lot off rags to remove undercoating in the engine compartment off my previous 944, but that is REALLY Meassy.
Eric Coffey 03-13-2004 11:21 AM
If you are referring to the nuts closest to the door/windshield, those are a b**ch to remove ! Much easier to get to with an extension and U-joint socket IIRC. So, why the fender removal anyway?
SmileWavy
john walker's workshop 03-13-2004 11:23 AM
the next problem will be that the fender is sealed to the body with a caulking strip. real tough and rubbery. you can actually ruin the fender if you don't approach this problem carefully. a stiff putty knife helps.
djmcmath 03-13-2004 12:05 PM
I'm pulling the fenders to look for rust. A recent thread showed horrifying pics of somebody else's (forgive me, I've forgotten who) '84 with the fenders removed, exposing rust along the entire joint. I suspect mine also has rust -- I live in the Seattle area, for crying out loud...
Stiff putty knife and a u-joint socket, eh? <sigh> Looks like I'm on my way back down to the hardware store. I already have some petrol, in various forms. I don't mind a mess, really, it's a lot better than damaging myself (or worse <gasp> my car!) by screwing up with a screwdriver.
Oh, BTW, what is the black cylinder inside the left front fender? It's about 11" long, 2" diameter, fixed to the fender with two hoseclamp-style brackets, connected into the rest of the car via a pair of rubber hoses. Fuel filter, maybe? I assume it's safe to remove it from the brackets and pull it out of the way so I can get at the bolts underneath right?
It's really encouraging to know I'm not the first to go through this nightmare. Thanks for all the help, I'll be back in a bit with a progress update...
Dan
Eric Coffey 03-13-2004 12:13 PM
black cylinder is the A/C receiver/dryer I believe. No prob with (gently) moving it out of the way. Or, you could simply choose to do the popular "A/C delete" while you're in there!
SmileWavy
svandamme 03-13-2004 12:15 PM
SmileWavy
flexible extension helps out a lot
and lot's of poking with a knife after you blow in there with a heat gun will help removing the stuff on the bolt, giving you a better grip
Eric Coffey 03-13-2004 12:50 PM
I never thought about using a heat gun, but sounds like a good idea! Just an FYI on the the flexible extensions though: The last one I used wasn't strong enough to hold the fastener. I like the positive feel of a U-joint and/or wobble extension rather than a flexible extension. YMMV.
SmileWavy
svandamme 03-13-2004 12:53 PM
didn't work for me either, till i heated up the sjit and carved away the stuff on it..once the flex thing can properly seat on the nut... you don't need that much power.. the key is getting it to grip fully
john70t 03-13-2004 03:02 PM
Move slowly, have plenty of cushioning and light, and use only one finger to lift them off. You'll get there.
Schrup 03-13-2004 03:16 PM
I second the heavy duty cup brush attachment. I used one on my cordless to get most of the undercoating off around my rear swaybar mounts. I followed it up with the dremel to clean out the cracks & crevices. Might I also suggest a good pair of mechanics gloves, they will save your fingers. I use Ironclad & love them.
ruf-porsche 03-13-2004 05:42 PM
Originally posted by Schrup
I Might I also suggest a good pair of mechanics gloves, they will save your fingers. I use Ironclad & love them.
Mechanic gloves?
What are you guys a bunch of sissy?
Work on all my cars bare handed all the time. Have all the scrape knuckles and scars to prove it.
Just don't stick your hand in the carb cleaner if you have an open cut. Oh, you sissy have CIS or Motronic or EFI so you never mess with carb cleaner.
Mechanic gloves, somerthing the ricers would use to reprogram their rice burners.
OldTee 03-13-2004 06:02 PM
I'm not sure I would use a heat gun on the left side. The fuel fumes might take some exception to being anoyed by a heat filiment.SmileWavy
djmcmath 03-13-2004 11:17 PM
Thanks for the tips -- your wisdom works great! I've obtained a heat gun, and it sure does melt that stuff. Melts slowly, but it does melt it. Apply a little heat, then scrape with a putty knife, peel the cooling remnants off by hand, check to see if the bolt is exposed enough to get a grip on, repeat as necessary ...
My next headache is removing the bumper so I can get the little screws out of the rubber bumper cover. The Bentleys just says to (among some other more minor stuff) remove the securing nuts and pull it off, which isn't working at all. I've tried gently tapping it with a rubber mallet and pulling on the bumper as if I really wanted a hernia, to no avail. I was planning on applying a little force, but this is ridiculous. Any more help?
Thanks again, all.
Dan
Schrup 03-13-2004 11:32 PM
Originally posted by ruf-porsche
Mechanic gloves?
Let's go on down to the dirt track thenhttp://forums.pelicanparts.com/uploa...1079249482.gif
svandamme 03-14-2004 12:39 AM
fuel doesn't ignite by heat alone... not even when it's evaporated and get's heat gunned. besides , if you would have that much fumes... to make any combustable mixture in your working space you'de have a splitting headache after say 1 minute...
911nut 03-14-2004 05:25 AM
Dan
Dan, soak those little rascals in generous amounts of PB Blaster overnight and they'll back right out. If that doesn't work buy a pair of needle nose vice grips to grab them and get them started.
djmcmath 03-14-2004 01:06 PM
No no -- the screws in the rubber bumper cover strip are easy. It's the bumper itself. I have to pull the bumper to get enough room to get access to those piddly little screws. I've pulled the nuts off the front, the ones that hold the bumper to the shocks, but no luck pulling it off. Are they additionally glued in place, or are mine perhaps just welded in by years of rust (ooh, worst case)? Should I just apply more force? Is there some magic fastener that I've missed that's holding these babies on?
TIA,
Dan
peter915 03-14-2004 01:51 PM
Dan,
I repaired both wings on my 85 coupe last year.
Found I had to replace metal along top of sub-frame.
See photo.
Wings are held on with self-tapper type screws (Porsche), screwed into "speed nuts"... I couldn't believe porsche would use these??????
I replaced all fastners with stainless steel socket screws - M8's.
Replaced all speed nuts with stainless blind nuts - excellent.
I can now remove a wing in around 35 minutes with basically one tool - a M8 allen key - I use a long extended type - T bar or ball joint.
ruf-porsche 03-14-2004 05:17 PM
TIA,
Dan
Look inside the trunk (or boot if you're across the pond). There are a couple of bolts that holds the front fascia panel.
djmcmath 03-14-2004 11:27 PM
Could you please clarify -- where inside the boot ... uh, trunk? Thanks.
Some more lessons learned:
- The heat gun is a fantastic tool, though totally indifferent. It will heat your undercoating equally well as it heats your hand, your pants leg, or anything else you happen to be foolish enough to place in front of it.
- Sitting on the concrete floor of your garage gets really old. Padding makes a lot more sense after just a little while.
- If you tell your room-mate "As soon as I pull this one bolt, I'll be up for dinner," that "one bolt" will be guaranteed to take 10 times as long as any other bolt.
Dan
JNadal 07-22-2004 05:05 AM
Mechanic gloves?
Cutting oneself on a rusty piece of metal or losing a fingernail isnt fun.
Also the gloves protect from heat and chemicals. I once had almost a half quart of hot oil run out of a filter in a very hard to reach position, after I removed the filter and realized that pain was kicking in, I took off the gloves and my hands were completely red, Lord knows what would have happened had I not worn the gloves...
dickster 07-22-2004 05:40 AM
wow, this sounds like hard work.
i may be missing something here but why rip it apart if you don't know it has rusted? can't you check before doing something so drastic? there must be signs?
i'm picturing everyone on the board running out to their cars to rip off the fenders to check for rust.........:D
good luck:)
djmcmath 07-22-2004 06:20 AM
There's really no way to know whether or not it's rusty. I mean, a Seattle-area car is more likely to rust than most other places, and an '80 is more likely to be rusty than an '89. I know that I found surface rust under my fenders, and was pretty happy to have found it before it got bad.
Dan
TerryH 07-22-2004 07:39 AM
Dan
Hope I never get this bored and please don't tear the walls off your house looking for termites. :)
targa80 07-22-2004 07:53 AM
good luck:)
Checking for rust up inside the front of the fender and the bumper shock support bracket area is impossible to do unless you are a doctor and have your own orthoscopic scope. The bumper shock support bracket has a ledge that dirt and moisture collect in and rust will eventually occur there even if the car is galvanized. Another area is at the top of the rear of the fender and the window cowling and the door frame. I had rust holes on one side of my car and rust occuring on the other side. Here are some photos of what I found on my 1980 Targa.
Yes ripping off the fenders might seem a little extreme to some but if you care about your 20+ year old car and live in a non dry climate it may not seem so extreme. I have seen pictures on this board of rust damage on a late 80's model car from Scotland with some major rust damage.
http://forums.pelicanparts.com/uploa...1090507692.jpg
http://forums.pelicanparts.com/uploa...1090507713.jpg
http://forums.pelicanparts.com/uploa...1090507732.jpg
http://forums.pelicanparts.com/uploa...1090507751.jpg
djmcmath 07-22-2004 09:36 AM
I'm right there with ya, Pat -- my next big project is ripping out the backseat to look for rust. Extreme? Maybe. But an ounce of prevention is worth a pound of cure.
Dan
DanTheCat 07-22-2004 11:06 AM
Tearing out the interior was pretty easy compared to what you've been describing. I had a bad leak from my rear window I had to investigate. Luckily no rust was found. Of course, I wasn't worried about reinstalling the big rubber insulation bit (or rather, bits after I was done). I don't know what they used to glue it down, but for a while I thought it was actually bolted in or something crazy like that. On my car there were two short strips of glue at the very back under the rear window that were literally impossible to pull up. I wound up tearing the rubber out and scraping the remaining rubber off with a screwdriver. A stiff putty knive would have come in handy. ;)
Good luck with your fenders!
Dan :)
