-   -   Suspension bushings and similar rubber bits.Replace on spec? (http://forums.pelicanparts.com/porsche-911-technical-forum/153392-suspension-bushings-similar-rubber-bits-replace-spec.html)
Dropp the Pilot 03-14-2004 06:44 AM
I have an '87 Targa which has lived all it's life in one of the hottest places on the planet. Just thought I should replace all motor mounts, bushings, etc on spec and if you agree could you post a list of what I need?
Might as well do it all at once.
Randy Webb 03-14-2004 11:18 AM
I'm not sure if an '87 will need it, but for an older car you want to replace all suspension rubber -- look in a Perf. Parts catalog for a diagram - shows the rubber in color. (tho I advocate buying from Pelican).
But first (FIRST!!) replace all the rubber brake hoses with new rubber ones -- I'd do that every 5-10 years. Flush fluid every 2 years.
And how old is the grease in the CV jonts, how do the wheel bearings feel, and how old is the tranny fluid?
