Any one know the GPH ratings on early fuel pumps?
Wondering what the GPH ratings are on early fuel delivery systems for carbs and MFI?
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
RETIRED
Well it's usually PSI and carbs run fine at 5 psi....dunno about MFI.
The carbs fuel pumps usually have a regulator between the pump and carbs.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Senior Member
The very scientific method I have always used to test fuel pumps on carbureted engine, is to take the hose off the carb and put it in a pop bottle. Remove the coil wire and have someone run the starter. The pop bottle should be full in roughly 20 seconds. I'm sure that's how they do it at NASA too.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Yes, I'm aware of psi, and have a regulator on my car. However, what i'm wondering is whether the pumps themselves have a gallons per hour output rating.
Yes, it's in the factory spec book.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
E motor 125 liters per hour
