Smog equipment on 1980. What does it consist of?
Besides the CAT. what other smog devices are on these engines?I don't see a smog pump or anything like that....
Thanks, Ed
1979 911SC (The only way to fly) 1999 740I BMW 2002 SLK320 MB 95 Surb w/26 Hallett Sportboat |
In addition to the catalytic converter; air injection (smog pump many have been removed - look for an extra groove for the air pump belt on the fan pulley), exhaust gas recirculation or EGR, and charcoal cannister to absorb fuel vapors. Jim
Where is the smog pump mounted at?????I am looking at California cars on ebay, and I just see one belt groove on on the fan pully......They all can't have taken them off, could they???
Is that it?????So if it has the Cat, then thats it?????
Hilbilly Deluxe
Do you have a smog sticker under your engine cover? There are codes on there which corespond to the equipment that should be on the car.
There is a decoder on the California Smogcheck web page here: http://www.smogcheck.ca.gov/stdpage.asp?Body=/GenInfo/Publications/Used_Vehicle_Smog_Equipment_Requirements-Jan_1993.htm From memory, my 82 has codes for Fuel injection, Cat converter and O2 sensor. Tom |
