-   -   CIS injectors injecting continuously (http://forums.pelicanparts.com/porsche-911-technical-forum/153812-cis-injectors-injecting-continuously.html)
Dr. No 03-16-2004 11:17 AM
OK, I got the ingine in and mostly installed without bugging the board much, but now I have questions:
I bought a 1974 911 2.7 with CIS with a wrecked engine, almost all parts included but the ignition and CIS in pieces. These have been re-assembled in a fashion that appears to match the diagrams (here and at the enormously helpful CIS primer http://members.rennlist.com/jimwms/CIS/CIShome.html).
But, when I turned on power to the pump, expecting to check the spray pattern while fiddling with the air plate, all injectors started spraying continuously. This richness does not seem like a cold start valve problem, so what would be the next adjustment? Moving the plate does not affect the pressure.
Thanks, and I have already looked for obviously titled threads in the archives.
ChrisBennet 03-16-2004 11:24 AM
Perhaps the fuel distributor metering valve is stuck?
-Chris
targa911S 03-16-2004 11:26 AM
CIS....Continuous. Injection. System.
kellzey 03-16-2004 11:28 AM
Yes... continuous injection is correct vs. sequential fuel injection.
ChrisBennet 03-16-2004 11:34 AM
targa911: Sigh. Yes CIS = Continuous Injection. He knows that. CIS squirts when the air meter is moved up by air - not when the just the fuel pump is running i.e. the fuel distributor only supplies fuel to the injectors when the motor is running.
kellzey: CIS is not the "flip side" of sequential injection. Sequential is just a flavor of Electronic Fuel Injection
-Chris
bigchillcar 03-16-2004 11:34 AM
Dr. No,
First of all...'sit down'...(sorry no caged spider available ;) )
I have the same '74 motor...the idea is that these spray continously from the moment power is applied to the fuel pump...air sensor plate meters the volume delivered depending upon condition...this is normal operation.
Btw, sorry Crab Key was destroyed...I was just doing my job...;)
Ryan (007)
:cool:
vash 03-16-2004 11:38 AM
i bet chris is right. the injectors dont spray when the engine is not running. you need the pillow of air to hold up the sensor plate. take the fuel dist off partially and peek under it, is it stuck. a good indication, is also; when you lift the plate manually, do you feel any resistance? no resistance like a perfectly balanced balance (that was an awkward sentence, sorry) usually indicates a stuck control plunger. even zilcho fuel pressure, there would be a tiny bit of resistance. but you already proved there is fuel press.
cliff
bigchillcar 03-16-2004 11:41 AM
Ack...my bad...Cris is right...they only should flow while the engine is running and the air sensor plate actively metering a fuel volume. Started to sound like maybe a stuck comtrol plunger...need to think a moment here...
Ryan
ChrisBennet 03-16-2004 11:46 AM
I did some work on a '74 CIS that had been sitting for a 10 years. The fuel distributor was gunked up enough that air wouldn't lift the plate but I could lift it by hand. To start the car I needed to lift the play by hand but after running it for a couple of days it worked fine.
Thinking out loud...
If your fuel distributor is stuck open I would think that the air meter plate would move with no resistance at all and then hit the "pill" that meters the fuel. If the "pill" is really stuck, the plate would stop right there. If the pill is just gunked up, you would be able to move the plate up further with some "gummy" resistance.
-Chris
Leland Pate 03-16-2004 11:50 AM
I'd also start at the fuel distributor.
bigchillcar 03-16-2004 11:51 AM
I'm with Chris on the stuck control plunger...it's the only think that would allow fuel to flow to the injectors...should be closed without engine running, but yours is apparently open. It's possible that the pivot lever between the air sensor plate and the plunger is having no bearing because the plunger is already stuck 'open' or 'up'....so movement of the plate has no impact, matching your symptoms.
Ryan
john walker's workshop 03-16-2004 12:03 PM
try just cranking the adjuster counterclockwise until they just stop spraying. if the piston was stuck you would feel no pressure on the sensor plate arm when you lift it, or at least some freeplay. the arm lifts the piston.
targa911S 03-16-2004 12:44 PM
Chris: sigh, that was tongue in cheek. I know nothing about CIS. I leave that to you experts. I've got my hands full with my MFI.
ChrisBennet 03-16-2004 12:52 PM
Sorry. I must be grouchy today.
-Chris
targa911S 03-16-2004 12:56 PM
I understand...it's cool.
Dr. No 03-16-2004 05:11 PM
Thank you all for your replies.
Yes the plate bounces up and down with no resistance or effect on the spray.
Is there a way to free the piston without taking the whole fuel distributor apart? I have "spare" CIS unit from a Rabbit I will dissect later for more data (it also bounces freely, but there is no fuel pressure to deal with).
And, yeah, I didn't thing 'continuous" meant filling up a couple of cyliders before applying spark.
1980SC 03-16-2004 06:10 PM
You can blow compressed air into the top, center port to loosen the stuck plunger. You'll probably want to remove the fuel distributor from the sensor plate housing first. Be sure to catch the plunger so it doesn't go flying. I wouldn't recommend disassembling the fuel distributor unless completely necessary. I've done it, but it was a huge pain to get it sealed up properly afterwards.
-Rob
1980sc
Dr. No 03-16-2004 06:56 PM
I think I'll try the compressed air route. The fuel distributor can be removed from the air box without dissasembly. Here are pictures from the 4-hole rabbit version. http://forums.pelicanparts.com/uploa...1079492183.jpg http://forums.pelicanparts.com/uploa...1079492198.jpg
Dr. No 03-16-2004 07:11 PM
And by the way, that was not really Crab Key--it was a decoy. Your day will come, Bond...
bigchillcar 03-16-2004 07:31 PM
But...I saw you disappear into the radioactive vat...?! Curses...
Ryan
Dr. No 03-17-2004 08:04 AM
Two hours of busted knuckles, BP Blaster, and finally a drill for the last of the three screws the FD is separated from the rest of the thing. The plunger is apparently welded in there--it won't even turn in place. Next--new/used fuel dist. or disassemble this one. Any advice on that job?http://forums.pelicanparts.com/uploa...1079539450.jpg
1980SC 03-17-2004 08:22 AM
Here's a pic of when I rebuilt mine. The plunger was stuck on this one too, but it was before I knew about the compressed air method. You can do it if you have the patience, or you can find a used distributor for around $200.
http://forums.pelicanparts.com/uploa...1079540276.jpg
-Rob
1980sc
ruf-porsche 03-17-2004 08:34 AM
Originally posted by Schrup
Might I also suggest a good pair of mechanics gloves, they will save your fingers. I use Ironclad & love them.
You're not the real Dr. NO. The real Dr. No always wore gloves.
Dr. No 03-17-2004 08:42 AM
Blue nitrile from Harbor Fright (sic) or purple nitrile from work.
Neither provides much cushion when the rachet slips.....
And here is my caged spider:http://forums.pelicanparts.com/uploa...1079541748.jpg
john walker's workshop 03-17-2004 09:52 AM
sometimes you can get a grip on the end tit with some needlenose visegrips and get it to move.
vash 03-17-2004 12:04 PM
dr, no. it will move. you gotta use carb spray. pb blaster is way to thick to get inbetween the tight clearances. think about it, gasoline cant get through. no way pb will even stand a chance. you may need a new FD anyways, so time to get medival on your existing one. at least that was my philosophy. needlenose pliers and carb spray. spray the bastard down, and grab the tip with the pliers and just start push/pulling it to get it to move. you will barely do anything at first, and then you kinda build up momentum. more spray and repeat. the smart money is on you, not the damn plunger. once it pops out, it may fly. dont let it hit the ground. you efforts would be wasted if you hit hit the flying control plunger against anything hard. like i said, the machine tolerance is amazing!
vash 03-17-2004 12:06 PM
you can get new screws to hold it down easy. and they dont need to be so damn tight. they only need to hold the FD down, and there are three of them!
ruf-porsche 03-17-2004 04:03 PM
Are you allowed to use t*t on this board?
If you have an understanding wife or significant other maybe putting it in a hot oven (450) for about a half hour will cause the metal to expand enought to allow you to remove the plunger.
Carb cleaner use to work fine for me. Just don't reach into the cleaner if you have scrapes or cuts on your hand.
Dr. No 03-17-2004 04:09 PM
Properly, it should be spelled "teat" and pronounced "tit".
When I said welded, I meant welded. Hemostat, needle nose, Visegrip, nothing will move it at all. The whole FD is now sitting in a can of Chem-Dip. Maybe for a week.
bigchillcar 03-17-2004 05:04 PM
"Underneath the mango tree..."
Sorry...didn't have anything in particular to add...just that...No will understand...
ruf-porsche 03-17-2004 05:54 PM
my honey and me
I understand.................
Dr. No 03-27-2004 09:32 AM
Mission accomplished!
Nine days in the chem-dip bucket, sprayed it off (I hate the way that stuff smells), grabbed the teat with the needle-nose (kinky) and it resisted a moment, and now moves freely. All reassembled and re-installed and the injectors spray only when the plate moves.
But now, no spark.
New topic....
Early_S_Man 03-27-2004 11:01 AM
Well, now that you have learned patience ...
Less brute force will be needed for the CDI system, but cutting and crimping will be needed for the bench test ...
http://forums.pelicanparts.com/porsche-911-technical-forum/155489-72-911-t-all-sudden-no-spark.html
vash 03-27-2004 11:56 AM
no spark is harder.
Andrew (Tiger) 10-25-2023 08:20 PM
Persist it will pop out
Just in case this helps, reviving an old thread.
I had the same problem, gas pouring into each cylinder when the ignition was on - CIS was sending fuel continuously. Culprit was a stuck fuel distributer plunger, which was as result of vanished fuel because car was sitting around for a couple of years during restoration.
I ended up taking the whole flapper and distributer off (didn't like the look of the tree screws), I used lots of carb cleaner on the plunger and then compressed air into the centre inlet on top of distributer to free the plunger with the distributer right way up on rags so that when plunger released it popped onto rags. It took some time and effort, and now running beautifully. Needless to say very happy. Thanks to this board and Pelicanites.
Dr. No 10-26-2023 07:46 AM
Wow, nice revival!
Procul 10-27-2023 07:02 AM
Great timing for me with the exact same issue. Wish I'd found this thread 8 weeks ago!
