motor/tranny mount question
I am thinking of trying to use solid mounts for my transmission to improve transmission feel. Any thoughts?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 03-20-2004, 04:37 PM
most guys that do that love it..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2004, 04:40 PM
Thanks! Anyone else?
Old 03-20-2004, 08:13 PM
keithdog72's Avatar
Send a message via AIM to keithdog72
I have heard that solid engine/motor mounts cause more vibration. I am thinking about putting solid mounts in also, so if anyone knows: how much difference in vibration with solid as opposed to rubber mounts?
1975 911 Targa
1972 VW Beetle
2004 Mercury Mountaineer
2003 Suzuki Intruder 800
Old 03-20-2004, 08:22 PM
Chuck Moreland's Avatar
Do a search, you'll find many opinions ranging from "Intolerable vibration" to "not much difference".
I would ask what problem are you trying to solve?
The real reason for putting in these mounts is that under extreme cornering loads (using race tires on the track), some cars flex enough that the shifter and linkage get out of alignment. This makes shifting difficult.
If you are not experiencing this problem, then I wouldn't advise taking this step. A street car with good stock mounts should not experience this problem.
I would advise replacing your mounts if they are worn. "Sport" mounts are available that are firmer than standard, yet still absorb vibration. These can be further tightened by inverting the large concave washers such that the "bowl" faces the mount. This is a nice intermediate step that would meet the needs of most without causing undue vibration.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-20-2004, 08:44 PM
Zeke's Avatar
Great thought. And rubber mount are there to help subdue drivetrain noise.
Old 03-20-2004, 08:57 PM
Randy Webb's Avatar
bowl faces the mount -- you mean concave downwards?
Old 03-21-2004, 02:36 PM
So you don't think this is a good idea? I was planning on using either stock or sport mounts on the engine end of things. I know there will be extra vibration but I am getting a good deal on these. That is why I am considerig using them.
Old 03-21-2004, 03:11 PM
There are two concave washers, one top and one bottom on the rear. Each would "cup" the rubber for max stiffness, but they would point in opposing directions.
Tranny has only one washer, and it would also cup the rubber.
Old 03-21-2004, 03:52 PM
Randy Webb's Avatar
Ok thx - Inside surface of bowl faces the rubber mount.
Old 03-21-2004, 06:07 PM
