Carello driving lights?
I picked up a set of carello through the grill driving lights for just this side of nothing. I can't seem to find any sort of references to what bulb it takes or if it's even made for a porsche. The model # on them is PF JOD or 02 405 584. Anybody out there have any idea's what these are?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
a little bump to show those in the know?
I can't help with your specific problem, but you might want to check with Cornpanzer. He's having some trouble finding bulbs as well - I think his are Carello's. Do they look like these? They're off a 70's Lancia Stratos:
Also, might find some leads here: http://www.goss.com/rrdistr.htm http://www.mbzponton.org/pax058/foglight/hella.htm |
My lens are different (they're white) but it looks like they very much are the same
those carellos take H3
(i have a set)
Harry Hoffman 68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?' 912 Registry charter member #912R0195-C | Early 911S Registry member #2070 http://hoffman912.blogspot.com/ |
Tim,
It would be a vey good idea to disassemble and clean up those lamps before you think about trying to use them. You can then take a look at the bulbs and ID them ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I've already disassembled them and unfortunetly one is missing peices (the holding trim ring) and both are missing bulbs, but when I got them they were free in the end (package deal, sold off other bits) so they've just been sitting.
(this thread is 6 months old)
RETIRED
Try the 356 weasels....they should be able to link you up with parts and bulbs.
www.356registry.com Go easy, as they are mostly crotchety old men with ZERO sense of humor....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Tim,
The mounting base for H3 bulbs are circular with two cutout 'notches' on opposite sides, one is semi-circular and the other is rectangular. The H1 bulb base is D-shaped. There should be tabs or cutouts where the bulbs mount to allow you to identify which bulb will fit.
