Fuel Delivery Problem On '78 Sc
The car would start right up, run for all of 3 seconds..strong...and then die. I replaced the fuel filter thinking it might be the problem and now it's not starting at all?
Any help would be appreciated.Thanks.
Gary C.
Gary
Old 10-31-2007, 07:12 AM
Designer King
Paulporsche's Avatar
Gary,
Could be quite a few things. You should try searching these symptoms.
Likely causes include the WUR, AAR, AAV, mixture, vacuum leaks and fuel pump.
A CIS fuel gauge from JC Whitney (c $60) will help.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-31-2007, 09:59 AM
azporsche911.com
Hoffmanmotors's Avatar
Yes get a CIS pressure tester tool.
http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=cis+fuel&searchbtn.x=13&searchbtn.y=9
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 10-31-2007, 11:24 AM
Bill Douglas's Avatar
The fuel pump electrical contacts, being under the car, get pretty ugly. An easy job would be to clean these and clean the contact where the earth wire bolts to the body - good luck.
And clean and reseat the fuel pump relay.
Old 10-31-2007, 12:44 PM
