Broken Side Mirror Remote Switch
did a search on this and came up empty...the side mirror remote joy stick isn't bringing me any joy. I've replaced the entire unit, being careful to replace each of the 9 leads into their correct orientation, but I'm still not able to engage the servo's for either mirror. Any thoughts?
Many thanks
Joe
79SC
Old 03-19-2004, 12:41 PM
I had a similar problem. My switch worked for the up/down adjustment, but not for the in/out. I replaced the switch (I have a new switch if anyone needs one) with no results, took the mirrors off and cleaned the servos, but they still don't work. I was able to find quite a bit of information with a search. Try some other words and you will them. Good luck.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 03-19-2004, 01:14 PM
