Aluminum or magnesium?
Need some info...I'm trying to determine if my case and tranny are magnesium or aluminum.
I've done the metal shavings test off both, plus a true aluminum piece for comparison. All tests with a torch result in glowing metal shavings but no fire (magnesium is supposed to burn, right?)
Here's the parts numbers...case 901 101 102 OR , stamped 901/17 10584
and the trans 901 301 101 OR
Thanks again.
Dan
'68 911L w/RSR
Gruppe 'B' Bastard Factor 1856
Old 03-20-2004, 09:20 PM
Zeke's Avatar
Oh boy, I wish I coudl tell you by the numbers alone. I could go look in my red book and probably figure it out. The reason I'm replying is that any alum cases I've had clean up bright and shiney with a number of household cleaners. Not so with mag. Dull gray no matter what you do. Many people paint it. I got a mag tranny nice by pouring acid over it. Not recommended, but it works. It'll ruin a gasket surface in seconds.
Old 03-20-2004, 09:35 PM
Send a message via AIM to fintstone
Well 901/17 is a U.S. '68 number...for a sporto engine, and my understanding is that the "68 model year used only mag cases.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-20-2004, 10:39 PM
Bird. It's the word...
Fishcop's Avatar
Flinstone is right on the 1968 vintage and the sporto, but 1968 crank-cases were aluminium, the change to magnesium occured in 1969. You will know magnesium when it burns... not just a spark, but a true "flare" as it burns. I believe that you have an aluminium engine.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-21-2004, 01:17 AM
Doug Steinel's Avatar
your case is AL
refer to Wayne's engine book, pg. 48.
77 911, 3.0L
Old 03-21-2004, 04:42 AM
Interesting! The B. Anderson book says that the case change to magnesium was spring of '68. Guess Wayne trumps BA!
Old 03-21-2004, 02:20 PM
Thanks for all the help. For reference purpose, the true build date of the car/engine was '67, build #11830165.
Is there a market for early 2.0 cylinders, pistons, and heads that are in great shape (no internal/external damage)? I'm planning on upgrading to 2.7's.
Dan
'68 911L w/RSR
Old 03-21-2004, 09:03 PM
