Broken Side Mirror Remote Switch
did a search on this and came up empty...the side mirror remote joy stick isn't bringing me any joy. I've replaced the entire unit, being careful to replace each of the 9 leads into their correct orientation, but I'm still not able to engage the servo's for either mirror. Any thoughts?
Many thanks Joe |
I had a similar problem. My switch worked for the up/down adjustment, but not for the in/out. I replaced the switch (I have a new switch if anyone needs one) with no results, took the mirrors off and cleaned the servos, but they still don't work. I was able to find quite a bit of information with a search. Try some other words and you will them. Good luck.
| All times are GMT -8. The time now is 07:37 PM. |
