-   -   And another radio related question. (http://forums.pelicanparts.com/porsche-911-technical-forum/154479-another-radio-related-question.html)
dwightp 03-20-2004 03:25 PM
I recently removed my radio, speakers, amps, antenna and related wiring. I'm gonna listen to the "3.6 overture" and opt for a portable MP3 when I must have musica. Anyway, radio is out and there's that hole in the dash. I'd like to make it a shelf for misc. There has got to be someone that makes a DIN size blank pocket for this space. Even another make and model with the "no radio" option. Any ideas who may have it?
I guess another option is to find one of the older DIN radios that was a complete removable (not just faceplate as currently available) and use only the outer sleeve.
I really don't want to go with just the blank. Don't need the gauge space.
Any other ideas?
TIA
RoninLB 03-20-2004 03:30 PM
a voltage gauge
a CHT gauge
vash 03-20-2004 03:42 PM
a really big, rectangular cigarette lighter? :)
vash 03-20-2004 03:44 PM
ok just kidding. what about a chassis from an old pull out stereo? you would at least have the template to cover the inside with some black plastic to fabricate a storage area. hell, you can even put a door on it.
ZOA NOM 03-20-2004 04:18 PM
Two words: eight track
onewhippedpuppy 03-20-2004 04:24 PM
I had a Nissan that had an original double DIN size radio, I replaced it with a single and a pocket I got at a local stereo store. Check with a place that does installs, I'm sure they'll at least have something generic that you can adapt. Good call on removing the radio, you do know that a pocket will add weight though?;)
dwightp 03-20-2004 06:26 PM
Just found the solution. Thanks for the response.
vash 03-20-2004 11:05 PM
hey! share the info.
kees 03-20-2004 11:36 PM
A little bit late, but....
I think this is a solution
http://forums.pelicanparts.com/uploa...1079858144.jpg
http://forums.pelicanparts.com/uploa...1079858166.jpg
http://forums.pelicanparts.com/uploa...1079858179.jpg
SmileWavy
Kees.
vash 03-21-2004 12:22 AM
slick!
