side glass limit
I can't remember how to adjust the regulator on a targa so that the side glass doesn't go too high. My recent purchase has that common ailment and I need to fix it or purchase a bilgepump. (I'd rather not do that)
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
You'll have to remove the door panel to access the adjustment. There are two adjustments, one for up limit and one for down. One of the adjustments is accessible through a hole in the door sheetmetal, the other can be reached from the large opening in the lower part of the door. Just look for the allen (hex) bolts. One caveat, check the metal frame that the window glass rests in. They can rust and start losing grip of the window, causing the window to raise up out of the channel.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
