I'm selling mine as I'm parting out my whole car, but I can't see any method of removing it.
1969'T' style, thanks-
-Rickeolis- 1986 Corvette |
Remove horn pad.
Horn wire while be attach the back of horn pad, Remove 27mm nut and washer. Pull it off.
83 SC (gone) // 72 T (gone) |
I wish it were that simple. I removed the horn pad already and there is no nut under it.
I need to get a pic to show what I'm seeing. Thanks-
Slippery Slope Victim
Look down in the empty space, in the neck of the steering wheel, there's got to be a nut holding the wheel to the steering shaft. If you put a 27mm socket on the end of a 10"+ extension I bet you can just insert it down into the wheel and land on the nut.
Mike˛ 1985 M491 |
Just went out and got this:
Are those three allen head socket screws into the hub? If so they obviously must come out in order to acess the nut.
Good Luck........Mike
Mike˛ 1985 M491 |
No, they are recepticles for bolts from the other side out, nothing I can do here...
thanks-
Wait a minute, is that a wing type wing horn button. If so you have to twist it off the steering wheel hub and then you have a clear shot at the nut.
Mike
Mike˛ 1985 M491 |
![]() i have no idea...sorry.
Rick
Looks to me like you screwed up and pulled the pad off the horn button. If you did not damage it, you can glue it back on. Press the rim of the horn button down on both sides at the same time and rotate counterclockwise. It should release. Stoney
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Stoney comes through again!! Thanks so much!
So rotate about 90 degrees, or does it unspin like a nut? Yeah, the pad came off easily, so I'll glue it back again...
-Rickeolis- 1986 Corvette Last edited by rickeolis; 03-22-2004 at 08:17 AM.. |
Righteous Indignation
Rick, What are you doing to my wheel.
![]() Is everything else coming out OK? ![]()
Michael “Electricity is really just organized lightning” -Dusty 70S Coupe |
Sounds good! As you see in the picture, it simply comes out as a X-shaped pad quite easily Michael, don't fret!
Everything is cool so far. TTYL- -Rick-
Just joshin ya
![]() And by the way. Get back to work pullin my parts! ![]() ![]() ![]()
I'm on it! All I lack now is the steering wheel and the long rods in the tranny linkage. I have the shifter itself out, TTYL-
Stoney and Michael- Got it!
Simple twist of the horn bracket like Stoney said, and viola! Thanks much- Michael, all I lack now for your order is the shifting tube back to the tranny, I'll e-mail you on this issue- -Rick-
'70 GS '73 911T '87 325IC "Let go of whatever holds you back" Last edited by KJensen; 10-16-2005 at 09:15 PM.. |
Thread Tools | |
Rate This Thread | |
