Nobody
bob tilton's Avatar
tranny leak at the support studs? fix?
discovered a few swepco gear oil drips on the garage floor. without digging too deep, leak appears to be coming from the front right stud of the tranny support. is this a common leak area or should i be investigating elswhere? cleaned up the area as you can see a fine film swepco on the edges of the tranny support as well. will take another look in the morning. how should i go about fixing this? tranny was recently rebuilt and new clutch package installed. new flywheel seal and seated properly.
thanks in advance.
Bob Tilton
www.werkcrew.com
Old 03-22-2004, 10:37 PM
Eugene at Pelican Parts's Avatar
It's highly unlikely those studs were even touched during the overhaul. I'd guess it's the end cover gasket. Perhaps the mating surfaces weren't scraped clean enough on both sections of the case.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 03-22-2004, 11:44 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
That gasket is pretty easy to replace once you drop the tranny. There's also the reverse light washer and the seal for the gear selector, but it doesnt appear that those are leaking (they are more forward, but it's hard to say).
Matt
'82 911SC Targa!
Old 03-23-2004, 06:35 AM
Senior Member
Superman's Avatar
For reasons I do not understand, gear oil flows in ways other liquids cannot. It can fool you. Those studs are not leaking. The oil is coming from somewhere else.
Mocha 1978 911SC. "Coco"
Old 03-23-2004, 06:49 AM
Other possibilities are speedo drive seal or the vent is oriented wrong (this usually makes a leak futher back though but it cound run forward and drip off the mounts). The vent opening should face in the 90 degree forward sector. If you have a 901 I believe the speedo seal is fairly easy to change with the tranmission in the car. Cheers, Jim
Nobody
bob tilton's Avatar
thanks for the input guys. i was able to spend a little time under the car this evening and it appears to be leaking where the tranny and support meets - see pic. i cked all other areas (flywheel seal and shift rod seal) for leaks with no luck. i don't know where that vent is that is mentioned. the support was removed when the tranny was rebuilt. i pulled the tranny myself and remember painting the support while the mechanic rebuilt the tranny. so it looks like the 2 surfaces are not mating flat? anyway i could only think to torgue the nuts down a bit, ck the 20 mm bolt attachments to the trailing arm area, and top off the gear oil. guess i'll just keep an eye on it.
any other suggestions? should it continue to leak i guess i'll need to remove the support and sand the areas flat?
Bob Tilton
www.werkcrew.com
Old 03-23-2004, 10:23 PM
