Oil Leak - where to start?
1991 C2 with 81K, had a top end rebuild 800 miles ago (before I owned the car) After driving a small amount of oils drips off the oil drain plug. This just started or was missed in the PPI. I am new at this and wanted to know where to start? Thanks in Advance.
Jones199 |
one of gods prototypes
is it coming from the drain plug or running down to it?...........
the crush washers on drain plugs "should" be replaced everytime they're removed.......maybe it's just too crushed and not sealing
Brought to you by Carl's Jr. |
It appears to be coming out directy from behind the oil plug - so I guess it must be the washer. Thanks
Jones199 |
yea, an easy one.
poof! gone |
