phoneguy's Avatar
Question Exhaust popping on decel?
Just installed used cat bypass and B&B 1 in - 1 out and it sound great on acceleration! Only problem is it pops bad on the deceleration. Any ideas? Thanks in advance!
Old 03-22-2004, 04:57 PM
bigchillcar's Avatar
i've heard of this happening with this change in exhaust configuration. i don't have an answer, but i suspect you'll be hearing feedback on the causes and solutions soon. if not try a thread search on the topic.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-22-2004, 05:01 PM
Most likely an exhaust leak. Go back and check all the connections and gaskets.
Ben
1986 3.2 Carrera
Old 03-22-2004, 05:08 PM
A Quiet Boom's Avatar
This is most commonly an exhaust leak as stated previously. On decel the drop in pressure sucks fresh air into the exhaust causing the pop, it's worse if the mixture is on the rich side to begin with. An old trick I used on V8's with headers was to run two gaskets instead of one and a little Permatex Ultra Copper sealant, I did the same when I built my custom exhaust for the 911 and haven't had a problem. You can also check that your vacuum advance is working correctly since this can also cause the problem.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 03-22-2004, 05:32 PM
Az911's Avatar
Send a message via AIM to Az911
My 3.0 with headers/bursch muffler makes the poping sound also. I think that is one of the coolest parts to haveing an open exhaust. Also I do not have an exhaust leak.
72T RS look
96 993
Old 03-22-2004, 05:40 PM
David's Avatar
If you used new gaskets and the parts were in good shape, I doubt it's a leak. My 930 does it as did my Honda Intercepter MC before I sold it. I've always thought it sounded pretty cool.
Old 03-23-2004, 08:50 AM
My 84 3.2 w/ GHL 1 in 1 out and a straight cat bypass did the same thing. Replaced the bypass with a Fabspeed Euro pre-muffler and the pop went away and the sound is much better, richer and less resonance.
crude rudy
'84 cab
'14 ZX-14R
Old 03-23-2004, 10:04 AM
AirCooledExcellence's Avatar
My SC with SSI's & Dansk does it as well, no leaks, sounds cool!
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 03-23-2004, 10:53 AM
Noel's Avatar
If this car is an SC and you have the vacuum line from the Deceleration valve disconnected and plugged (To help the revs drop faster between shifts) this is normal.
In fact the popping may have been there all along but merely muffled by the cat.
Noel
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 03-23-2004, 12:45 PM
I am with Steve and Tim, I like that sound. I switch to SSI exchangers and a Dansk 2 in 1 out muffler and the one thing I miss is the popping on deceleration.
Old 03-23-2004, 01:36 PM
