-   -   73.5 Flasher relay (http://forums.pelicanparts.com/porsche-911-technical-forum/154920-73-5-flasher-relay.html)
Red911t 03-23-2004 01:21 PM
73.5 Flasher relay
It looks like I need to change the turn/flasher relay, does anyone know where it's located?
Jim Sims 03-23-2004 01:39 PM
Up front, through the trunk behind the felt pad on the driver's side on the "firewall" side of the dash. Be sure it's the flasher as they are quite expensive. Jim
bigchillcar 03-23-2004 02:43 PM
ken,
can't say for sure that i know what your problem is (ok, that sounds funny), but for me it was the best 30 something dollars I've spent on the car. If your indicators on the gauge are doing funny things like, both flash when using them, etc. and have ttried in vain by chasing bad connections at the corner lights, this will probably make your day...
Ryan
Red911t 03-23-2004 03:25 PM
Both the turn signals and the emergency flashers stopped working, I had already ordered and new relay and have now installed it and everything is back to order, not an easy place to get at.
Thanks all
