-   -   Turn signal will not shut off. (http://forums.pelicanparts.com/porsche-911-technical-forum/154994-turn-signal-will-not-shut-off.html)
jcc911 03-23-2004 07:17 PM
OK guys,
I have a '78 SC and I recently replaced the steering wheel with a 930S version.
Upon activating the turn signals and turning left, it turns off by itself upon completion of the turn. However it does not turn off when turing right.
Did I instal the hub incorectly? If how should it be positioned when installing.
Thanks,
Jeremy
palle7688 03-23-2004 08:35 PM
It been a while since I've had my steering wheel off so I'm not 100%.
No, you did not install it correctly. On the steering wheel (boss) there are a pin that should activate two fingers on your turnoff switch. As I recall you risk breaking it if you install it incorrctly.
