-   -   Search no longer pulls old threads - we're losing information. (http://forums.pelicanparts.com/porsche-911-technical-forum/155069-search-no-longer-pulls-old-threads-were-losing-information.html)
Jdub 03-24-2004 10:49 AM
I have been using the Search button to try to pull up older threads that I know I put out there - no luck. It appears our amassed wisdom is being lost.
Wayne: have we lost this information for good or is it existing on another server disk/db? Can we get it restored? I hate the idea of a "moving Search capacity" that eliminates what we've posted in the past.
I think this is pretty important.
John
emcon5 03-24-2004 10:59 AM
Seems to be working here. I dug up a post from 1998, searched for some key words, and it came up.
Search for
brake light switch replaced Napa
You should get this:
http://forums.pelicanparts.com/showthread.php?s=&threadid=28711&highlight=brake+l ight+switch+replaced+Napa
If they are from before the server software was updated, they will not show under your username (really old threads, users show as "Guest". Try searching with the "posted by" field blank.
Tom
Jack Olsen 03-24-2004 11:35 AM
If you're using your user name as part of the search, that might be the problem. Wayne changed something at one point so that a lot of my older posts are by a "JackOlsen" who isn't a member.
Jdub 03-24-2004 11:43 AM
Jack:
You are correct -- pulling the user name revealed many, many more posts.
Worth remembering I guess.
John
pwd72s 03-24-2004 01:14 PM
I'm terrible at searching. So, when I find something important to me, I'll print, place in a notebook binder I have that is divided into various categories. Kind of a private workshop manual, I refer to it often.
Bill Verburg 03-24-2004 01:17 PM
There is some sort of limit on how many posts user name will return. I haven't been able to directly access my early posts in a long time except indirectly when searching for something else.:(
Dantilla 03-24-2004 01:19 PM
Should I regularly start a 911 vs.944 thread just so we don't lose such valuable information?
RickM 03-24-2004 01:20 PM
If I'm not mistaken you used to be able to pull up threads you started. Now if you use your name as an argument you get every thread you've ever participated in.
Bill Verburg 03-24-2004 01:21 PM
Nope, there is a limit
RickM 03-24-2004 01:34 PM
Quote: "Nope, there is a limit"
Yes, I guess my point was that ytou see everything up to that limit.
H.G.P. 03-24-2004 02:32 PM
Tholian Web...star date: 5693.2
