Are you sure the idle switch is working all the time? Using a multimeter, make sure the contacts close when the button is pushed, and if necessary, do a continuity test for the idle switch at the wiring harness at the DME. Perhaps the rubber button on the microswitch is hardened causing it to hang? Make sure there is enough slack in the throttle linkage so the switch closes consistently. Also, make sure there is nothing in the way of the throttle linkage that would cause it stick or hang. Adjust the base idle speed per factory procedure at Kevin mentioned, but it sounds 'possibly' it may not be set right. Bridge b and c on the test socket on the left side of the engine compartment, and adjust base idle speed for 84-86 at 800 rpm. 87-89 at 880 rpm.
http://forums.pelicanparts.com/uploa...1080321730.gif |
Kurt,
My car has an '86 engine in it. It does exactly the same thing! Linkage isnt hanging up but the idle hangs at 2,000 RPM until I blip the throttle. If you figure it out maybe you can fix mine in September at the car show? He he he... |
Kurt - did you ever get to the bottom of this?
I have what sounds like an identical problem with my UK '88 Carrera. IACV is clean and I've checked the idle switch operation. The car is hanging onto the revs when hot. As with you I do not believe this is a 'mechanical' problem (i.e. to do with the throttle linkage). ANy further thoughts? I have recently replaced the DME simply to give me the old one as a spare. |
My 1987 had the identical problem. I went on a 2000 mile trip this summer and now it very rarely does it. I did run Techron on the trip. I have no idea if any of this is just coincidence but something definitely changed. I just hope it changed for good! I have probably put on 2-3000 miles since that trip and it is running fine.
This happens with my 80 SC as well. I can bring my down by letting the clutch out a little while still on the brakes. otherwise it is high enough to just let the clutch out in first. The car will just start rolling.
That's what I thought. Is there any way to chekc the decel valve?
On mine it turned out to be a combination of things. First, the clutch cable was pushing against the linkage down by the tranny, had to do some adjusting there. I also had a cracked connector where the cruise control cable snap into the bracket by the throttle housing. Tie wrap took care of that.
Hi Kurt
Thanks for your update. I dont have cruise control and have the G50 gearbox with hydraulic clutch actuation. I've had the revs actually climb whilst not touching the accelerator - makes me think it's not a mechanical problem (with the linkage). I guess I'll have to check the linkage out thoroughly for problems. |
Blatant bump.
Anybody have any further suggestions? Thanks. |
Check out this web site (www.systemsc.com) on Troubleshoot & Diagnostics
pages possible help in solving your problem. |
Thanks Loren - I'll take a look!
Check your CHT and IAT when this happens. You can check them at the harness of the DME, after taking the connector apart, and plugging it back in the DME.
Although, I don't know why they would go to 2000 rpms exactly, I could see 1400 but not really 2000. :( Good luck. |
This is my experience with fast idle problem. After a few minutes warm up, my 1987 Carrera 3.2 idle is normal at 850 rpm. After driving for a few miles the idle rises to 1200 rpm at traffic stops. In a hit or miss effort to fix the problem, I was adjusting the black plastic adjustment fitting at the end of cruise control cable and the plastic cracked. Somewhere on this board, I saw someone repair the adjuster with zip ties. I did the same repair procedure, and now the idle at traffic stops falls from 1200 rpm to 1000/900 rpm range. I am thinking the problem is not electronic and replacing the cruise control cable will solve the problem. Any comments or ideas?
Guess I should have posted an update at the time, but my problem was down to a hanging linkage. Once cleaned and lubricated at the gearbox pivot it was fine.
Thanks UK for your update. I'm almost certain my high idle problem is mechanical. Repairing the broken adjuster on the cruise control cable seems to have helped but has not entirely solved the problem. And now I find I can slow down the idle by pulling on the top of the accelerator pedal and drop about 900+/- revs. I'll check and clean the gearbox pivot point. Perhaps that will do it.
Maybe pointless suggestion from a hack mechanic but-
Check the back of your accel pedal, the ball on the end of the linkage snaps in a socket there. Pedal is most likely nylon, which can swell and tighten the fit in high humidity. Wouldn't hurt to inspect , clean and put a touch of lithium grease on the ball befor you pop it back in. |
Check the linkage from pedal to engine. There's a lot of links and pivots and springs along the way to deal with.
As far as the cruise control cable? It should be adjusted to be without slack, but that's it. It's got nothing to do with throttle operation, other than being a potential obstruction to the throttle working properly! You can disconnect the cruise control cable entirely to temporarily diagnose of course. |
I had simular problem with my 84 3.2 would not idle down from 1500RPM from time to time but the idle switch was being contacted by the linkage. But I caught it idling at 1500RPM just as I pulled into the garage and I left it running at the 1500RPM then I pulled the connector for the Idle Stop switch and jumpered the connector and the idle came right down to 900RPM. So don't trust the switch even if it clicks at idle! I just replaced the switch and problem went away.
It is troublesome that your car creeps up 1000RPMs when you unplug the switch. If I unplug the idle stop switch at idle on my 84 3.2 it creeps up about 500 or so RPM to the 1500RPM area. Did anyone touch the CO adjustment screw on the Air Meter? |
Fast idle seems to be solved by cleaning and lubricating linkage at the accelerator and at the bell crank mounted on the driver side of the G50. Diagnosis was simple when I realized a slight tug at the top of the accelerator pedal reduced the RPM from 1200/1300 range to 900. All the chatter here about idle control valves, vacuum leaks, cruise control cable adjusts, timing etc. gets to be confusing. After 6 months of '87 911 diy maintenance, one principle remains true - always analyze the obvious first. |
| All times are GMT -8. The time now is 09:24 PM. |
