Targa top a little too high
I need to correct this situation has anyone replaced the seals on their targa. Any good links that show installing these seals?
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
More info please-did you put in a new sela and the top is now too high? If so, this is a known issue-the current seal is a smidge too thick along the top of the frame for pre 89 cars, and needs to be "shaved".
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I acutually was able to adjust the clips on my top to fit tighter. Do you actually need new seals or a tighter fit?
944 TURBO!!!! 1982 911 SC Targa (loved but sold!) 2005 Cobalt SS (0-60 in 6.1!!) 2003 BMW 325i ex got in divorce 1969 912 Coupe (sold) PCA Member |
I haven't put the new seals in yet. I've tried to adjust the top but can't pull it down enough. The PO had the seals replaced an it looks like they did a poor job. It leaks terribly.
I have a friend with similar year and his seals are lower by about 3/8 inch. I would like to save the seals and just move them down a little. I have an extra seal in case I can't save the old one. greglepore: whats with the shaving that you mentioned?
Do a google search for carsinc of New Jersey. Dan, the owner, has instructions he can email you. Essentially, you take a razor blade and remove about a 16th along the lower edge of the seal, test fitting as you go. I suspect that whomever did it for the PO didn't do this.
