I'm not here.
Targa, Windows too high!
How do I lower the windows, they roll too high and lift my top. Is this an easy one?
It's my daily driver and don't want to take too much time out!
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
You have to take the door panel off, there will be two slots about a inch and a half long with a allen bolt, one toward the front and the other toward the latch at the middle to bottom, slide them left or right to raise or lower, they slip so you may wanna use so thread lock, Kevin
Ya, what he said. If you have a Bentley's manual, it shows you how to remove the door panel so you dont goof it up
Matt '82 911SC Targa! |
I'm not here.
thanks.
Go Gators!
An easy job--one of those typically German-engineered adjustable mechanisms that makes absolutely perfect sense--after you take apart all those pieces that cover it up!
Timothy Stoops Air '62 356 B-‘86 911 Cab H2O '12 Cayenne |
I'm not here.
PS: where do I get a Bentley's manual?
Platinum Member
Pelican, of course. http://www.pelicanparts.com/catalog/shopcart/BOOK/por_BOOK_BKPTEC_main.htm
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
K. Roman - Just curious if you did this procedure and if you found it easy and problem solving? I have a window that always appears too high at the front, but OK at the back. It crunches the seal when I shut it unless the window is part way down. From the sounds of this thread the adjustment mentiond would likely solve my uneven problem too (I think).
************ '86 Carrera Targa |
