-   -   Anyone know what this EFI part does? (http://forums.pelicanparts.com/porsche-911-technical-forum/155793-anyone-know-what-efi-part-does.html)
jazzbass 03-29-2004 08:44 AM
Anyone know what exactly this line is for?
http://forums.pelicanparts.com/uploa...1080577747.jpg
This runs from the intake section between the air flow meter and the throttle body to a line behind the left intake manifold. The parts diagram from Pelican:
http://www.pelicanparts.com/catalog/...-07-00b-24.jpg
While doing spring maintenance I went in to remove some sound padding that had disintegrated. When I removed the heat blower motor, I found this:
http://forums.pelicanparts.com/uploa...1080577937.jpg
A nice big crack in the rubber part of the line. This line seems to be a breather or vacuum line of some sort, so I think grinding off the crimped section and clamping a new rubber hose on will be fine. Just want to make sure, though.
I will say that this worries me quite a bit about the condition of my 19 year old rubber fuel lines. I checked them and did see any breaks (or smell gas), but I'm still concerned.
ChrisBennet 03-29-2004 10:19 AM
Yes, just replace that part with some rubber hose. See Hunting down Motronic vacume leaks: What does the thermo-switch do? for examples of just this thing.
-Chris
dwightp 03-29-2004 10:29 AM
I believe that particular piece is to support the brake vacuum assist system.
jazzbass 03-29-2004 07:34 PM
Thanks guys. I'm going to grind off the old fitting, get some vacuum line and clamp it back together.
