Heat exchangers on a 2.8/twin plug setup
Right now I have headers on this car and I would like to put heat exchangers on and not give up to much on performance.So what would be a good solution.P.S. Just found this site and it is great
Welcome aboard! You realize that it is customary for new guys to provide mucho pics, especially if they have a 2.8 twin plug beast
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
It shall be done!It is asleep right now and does not like to be awakened after dark,so tomorrow I will take pics Cheers
I would use good old SSI's
drag racing the short bus
I guess it depends upon how efficient you want the headers. I like my '74s, but supposedly SSIs work better because they're true equal length and have more of a custom fit for the size engine you're running - hence there are sizes above and below 3.0.
Headers are good because they're about ten pounds less - no heat shrouds. But you have no heat. When exhaust starts getting up into the above $2K bracket, I start to think about Maui instead.
The Terror of Tiny Town |
Well thanks to all of you for the advise.So I guess the only real option is to fabricate a set of heat exchangers for my headers.Will let you know how it goes.
