Hallo ... could't someone tell me:
what the worksequence is for replacing, original Boge schockinsert(s) with Yellow Koni's? Wich bold to unbold first... and so on? Do i have to take the whole schockleg/strut off, or can i do it a faster way? Does someone has pictures, that show how to do it? Could't someone help me out here??? Dudes thnx ...
Andrew:wanna convert my 87- 911 to 964 C2-look. |
You can find that as a project in Wayne,s 101 projects book. It,s not that hard to do, i took about two hours for both sides. I did the yellow adj koni,s as well and love them. Here,s what to do:
Take the nut of on top of the shock under the hood. Then go in the wheelwell and pull the shok down. There,s just enough room to get the shock from under the fender (make sure your wheels are straight). When you have the shock from under the fender take the dustshield off and take off the nut that,s holding the shock in place. Take out the old boge shock and replace for the koni. Do all things in reverse when installing it shoulden,t be too hard. Cheers, Ed ![]()
87 Carrera Backdate |
Ok, thnx Dutchie...
I thought i had to a very difficult job, by breaking down a lot of extra parts first. But now .. with your help i can do it much easier & quicker. I will start rightaway... many thhx.
