91-C2-Targa, Repacment of the Rear Engine Lid Shocks is on the todo list this weekend. Any Advice? Thanks in Advance
Jones199 |
Recreational User
Put two in. One isn't enough to hold the lid up.
Virginia Rocks!
Make sure you have really long arms.
I don't know about a C2, but I took off the heater hose to get to the back nut. If you start by taking off the front nut, the back one is a lot easier to remove - no pressure on it! When you reinstall, hold the lid up with one hand while threading the bolt through. Porschenut suggests 2 in back. I think you only need that if you have a tail, but I guess a C2 has a tail....
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
The C2 has a "tail" that extends at 50. When you say put in 2 do you mean 2 per side (4 total)?
Jones199 |
Virginia Rocks!
There is probably not a bracket on the other side. So you're looking at 2 - total.
Regenerated User
Is there a trick to getting these things back in? Maybe I'm just a weakling.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
Virginia Rocks!
Bolt in the back one first. Then, open the lid as wide as you can and then you should be able to slide the front bolt in really easily.
