I'm planning to invest in a set of SSI heat exchangers soon, given the claims, a set that I hope to have a long time. Initially they will go on a 73S spec engine I'm building up. However, in the next 12-18 months I would like to upgrade to a 80-83 SC and want to transfer these to that car. Question is, given that criteria, what model SSI do I buy?
Do I buy the thin flange with the O2 sensor installed and plan later to shim the longer SC studs to make them fit, or do I buy the later model thick flange and change to longer studs on the early engine? As far as I see, these are the only differences? Thanks in advance to all you gurus out there for the advice... Fred |
SCWDP- Shock and Awe Dept
Doesn't the SC use thin flange?
Are you upgrading to a SC, or an SC engine? If a SC, get the o2 equipped exchange if you have to deal w/ smog inspections, otherwise don't worry about the o2 sensor.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
SC's have both thin and thick flanges. I had thin on mine.
78/79 is thin. replacing all the studs on the 73 would be an ordeal, unless you have the heads off and use a drill jig. they don't just unscrew.
Information Junky
it's easier to make long-studs shorter, than it is to make short-studs longer.
=> go with the thin-flanged. a stack of washers can make make long-studs (effectively) shorter.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I would say go with thin flange like island911.
As I recall both the '73 and SC are using short studs. As for O2 sensor, I don't know but again it's easier to plug a unused hole than drill one and weld in a nut/thread for the sensor. I bought my thinflange SSI for my SC but later upgraded to Carrera 3.2L engine, transfered the SSI's using lots of washers. With Dansk sportmuffler it's sounds sooooo good.
You might not be happier owning a Porsche, but it certainly feels so driving one |
