Parking/Driving light fuses...still down..
I thought I had nalied this thing today, but not so...
I've gone through 5 5amp fuses on the number 18 port of the fuse box..."Left side parking light/front and rear". Put a new one in, turn on the lights, then boom..burnt fuse. I've also searched the heck out of this site yet am coming up empty handed on the symptoms so I can compare. Headlights are fine, turn indicators are fine, parking lights(front and rear) right side are fine... Is there a relay I should be looking at...?? Also, I had heard that the engine comparment light may be on that same wire...and that hasn't been working.. I'm at a real loss now.. Phattey...
'87 911 '95 4Runner '05 Screamin Eagle ElectraGlide |
You have a short to ground "down stream" of the fuse in this circuit. The engine compartment light is on this circuit and I would check it and it's switch for a bare connector or wire contacting the body sheet metal (deck lid or hinge). Jim
Phattey, did you do anything to the car recently? The reason I ask is that I had the same problem after installing the rocker deco kit on my 67 912. I had apparently cut into the wires when I inserted the studs that hold the deco piece on. I took it to a shop and it cost me $50 to fix. I agree with Jim. Somewhere you have a short where metal is contacting an exposed portion of the wire.
Good luck, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
I've done a couple of things recently...
Replaced the shiftrod and ball socket bushings, replaced the worn engine deck lid shock. I replaced a bulb in the engine compartment, but it didn't work. Also, the latch that helps support the rear condensor fell off...it had only 1 of 2 screws holding it in. I just haven't put it back on... That's really about it... ???
The rear deck shock work and or changing the bulb have done something. Look closely for a bare wire or lug/contact up against bare metal. Check the shock mounting area for close proximity to the deck light wire/switch. Take the light assembly and it's switch off the deck lid and see if the short goes away. Jim
The rear deck shock work and or changing the bulb have done something. Look closely for a bare wire or lug/contact up against body sheet metal. Check the shock mounting area for close proximity to the deck light wire/switch. Take the light assembly and it's switch off the deck lid and see if the short goes away. Jim
