Copper isn't the best choice as it work-hardens and becomes brittle relatively easily. Brass would be the better choice, that is what the factory used. I would have spliced in brass patches only for the crushed section, making the splices as small as possible. I suspect it will work for a short-term patch though.
Chuck Moreland - elephantracing.com - vonnen.com |
My oil cooler had a coulple of crushed
places in the straight portions of the line so I bought some brass tubing that had an id slightly larger than the od of the old line, sectioned it in with a 1/2" overlap on each joint. Used silver solder like the hvac guys use with a piece of asbestos between the car body and line to avoid any damage. just made sure to not allow any contaminants to enter lines when cleaning then cutting the brass. This place has the brass tube:http://www.specialshapes.com regards, Dave |
Automotive Monomaniac
Is this hot enough to cause concern?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
one of gods prototypes
i understand the concerns, i think the pipe and solder will hold fine with the temps, but body flex/vibration will probably cause some leaks/cracks in the joints over time.......how much time? i have no idea.
i don't have plans of driving far with this on, just a temporary fix until i find a used line to replace it with...... i'm curious myself to see how long this could last........i don't however want to find out
Brought to you by Carl's Jr. |
"PS......i still need to find a used line.....this is ONLY TEMPORARY so i can make sure everything is in order for the hershey trip......i plan on having an oem line on by then" "i'm curious myself to see how long this could last........i don't however want to find out" I know you know: when your "new" line give up it's going to be expensive. I would have taken the patched path. I know a guy who installed a piece of rubber hose between 2 sectioned oil tubes. Luckily for his engine he spun of the track, in his own oil, when it gave up.
You might not be happier owning a Porsche, but it certainly feels so driving one |
dwil, can you remember id/od of your line. I need to do this to my oil line. Simon.
19 years and 17k posts...
Bell,
I hope all goes well, I kinow you're looking forward to Hershey. Good luck!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
problem is solved.......a bbs member is shipping me a used line this week for a fair price
i'm gonna have the copper patches brazed (stronger than solder) and hang it on the wall for a future emergency ![]() i run my 3.2 pretty hard .........like it's supposed too be........hate to have this ruin my day. thanks guys
Simon,
Sorry that I don't remember the id of the line. I just measured the od of the line on the car w/ a caliper and ordered the id line that fit over that od. It was a fairly loose fit but the silver solder filled it nicely with no leaks. The replacement section was cut 2" longer than the bent section that was cut out so it wouls overlap 1"n each end. Good luck, Dave |
I had the same problem. I took my lines off (both were crushed almost to halfway closed) and clamped them in a vice to reshape them . It required several rotations of the oil line but I eventually got them to about 90% round.
I was contemplating the same patches and fixes described here. A few engineer types suggested high pressure water to reshape it from the inside out. A plumbing and hydrualic fitting buddy recommended the vice. Since it was brass it was easily reshaped.
'83 SC |
the line i removed was very flat.......if it wasn't as bad it could've been saved.
