-   -   Spark Plug Question (http://forums.pelicanparts.com/porsche-911-technical-forum/156687-spark-plug-question.html)
hobieboy 04-03-2004 12:44 PM
Spark Plug Question
I have read in different places that platinum plugs are not recommended for the 80s vintage 911s...
So am wondering:
a) Why?
b) What plugs are you guys using? In my case, I'm looking for plugs for my 87 930, so would love to hear from other owners.
thanks...
slakjaw 04-03-2004 01:42 PM
Platinum plugs were designed for newer caes with a waste spark, (Distribotor-Less) Iginition systems. They are designed to spark in both directions. They would work in your car but why spend the extra money? when there are cheaper plugs that were designed for your iginition system.
Kyle
Early_S_Man 04-03-2004 02:44 PM
Patrick,
I don't think the ignition system has anything to do with it, and certainly the 'fire from both directions' sounds like pure advertising hype!
The platinum plugs do not seem to exhibit long life or resitance to fouling used in cars without EFI. My feeling is that the heat range 'latitude' isn't very wide, so, consequently, they offer no advantage on carbureted or non-EFI cars without precise mixture control. My experience on carbureted engines was that they fouled sooner than a good copper-core plug ... and that was on American V-8s and Japanese 4-cylinder engines!
slakjaw 04-03-2004 03:09 PM
hey if you have a a DIS car try it
run it with a plug out
hold the plug to engine ground the spark will travel "backwards" during the waste spark.
hobieboy 04-03-2004 03:34 PM
Hi folks,
Thanks for the confirmation... And Warren, I also heard the same reason you mentioned.
So the million dollar question - what plug should I use then?
thanks...
Wil Ferch 04-03-2004 04:00 PM
Bosch Plugs..either the copper or silver...should be great.
NGK copper in the proper heat range are very good too, and have nicely finished threads.
---Wil Ferch
jazzbass 04-03-2004 07:02 PM
Check out Steve W's excellent reply the platinum plug question here:
http://forums.pelicanparts.com/showthread.php?s=&threadid=156488
I hear Steve knows a thing or two about 911 ignitions ;).
stlrj 04-03-2004 09:59 PM
Autolites work well too.
hobieboy 04-04-2004 07:26 AM
Sounds like all I need to get is copper/silver ones in similar heat range then :)
Sure will save a few $$$...
Thanks!
