Power antenna replacement
My friend's '82 Targa SC has the factory power antenna. The telescoping and goes up part way and binds. It is completely frozen. The motor can be heard for awhile until it stops. Isuspect replacing the antenna wand is all that is needed.Can anyone give me advice on what to buy (smooth or toothed push cable) without having to dissect this deal?
Thanks.
CWL '86 Carrera Coupe '88 Carrera Cab '02 525i Sedan |
It might depend on what make it is. Mine was a toothed belt but I'm not sure if it was the original arial at that time. Might be best just removing the shaft to see.
Edit: Due to poor spelling ![]()
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l Last edited by Glasgow 911SC; 04-05-2004 at 09:13 AM.. |
Not Quite Banned
Look at the top surface of the mast - there will be some identifying info if it is a Hirschmann.
Then go here... http://portal.hirschmann.com/
Thomas Owen 1972 911T 1972 911S |
