Parking/Driving light fuses...still down..
I thought I had nalied this thing today, but not so...
I've gone through 5 5amp fuses on the number 18 port of the fuse box..."Left side parking light/front and rear". Put a new one in, turn on the lights, then boom..burnt fuse.
I've also searched the heck out of this site yet am coming up empty handed on the symptoms so I can compare.
Headlights are fine, turn indicators are fine, parking lights(front and rear) right side are fine...
Is there a relay I should be looking at...?? Also, I had heard that the engine comparment light may be on that same wire...and that hasn't been working..
I'm at a real loss now..
Phattey...
'87 911
'95 4Runner
'05 Screamin Eagle ElectraGlide
Old 04-04-2004, 07:01 PM
You have a short to ground "down stream" of the fuse in this circuit. The engine compartment light is on this circuit and I would check it and it's switch for a bare connector or wire contacting the body sheet metal (deck lid or hinge). Jim
Old 04-04-2004, 07:25 PM
DavidI's Avatar
Phattey, did you do anything to the car recently? The reason I ask is that I had the same problem after installing the rocker deco kit on my 67 912. I had apparently cut into the wires when I inserted the studs that hold the deco piece on. I took it to a shop and it cost me $50 to fix. I agree with Jim. Somewhere you have a short where metal is contacting an exposed portion of the wire.
Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-04-2004, 10:31 PM
I've done a couple of things recently...
Replaced the shiftrod and ball socket bushings, replaced the worn engine deck lid shock.
I replaced a bulb in the engine compartment, but it didn't work.
Also, the latch that helps support the rear condensor fell off...it had only 1 of 2 screws holding it in. I just haven't put it back on...
That's really about it...
'87 911
'95 4Runner
Old 04-05-2004, 04:04 AM
The rear deck shock work and or changing the bulb have done something. Look closely for a bare wire or lug/contact up against bare metal. Check the shock mounting area for close proximity to the deck light wire/switch. Take the light assembly and it's switch off the deck lid and see if the short goes away. Jim
Old 04-05-2004, 06:24 AM
The rear deck shock work and or changing the bulb have done something. Look closely for a bare wire or lug/contact up against body sheet metal. Check the shock mounting area for close proximity to the deck light wire/switch. Take the light assembly and it's switch off the deck lid and see if the short goes away. Jim
Old 04-05-2004, 06:25 AM
