robhamster's Avatar
Red face Carrera Footwell blowers
Are there footwell blowers besides the main fresh air blower that is in the trunk? I also have an a/c blower in the trunk. I had a short on smoke filled the car, and I narrowed it down to a wire that connected to the heater blower control and now the heater does not work as well as it did and there is less noise, so I suspect some blower is not functioning though the fresh air blower does work.
1984 3.2 Cab (now toy)
1975 911S (old toy)
Mercedes E350 W4 (snow car)
2007 911 Turbo (water and air pumper)
2012 Panamera 4S (for the wife, I swear)
Old 04-04-2004, 08:49 PM
Colby's Avatar
Send a message via AIM to Colby Send a message via Yahoo to Colby
Yes, there are a pair of footwell blowers and they are notorious for seizing. Mine ('84) didn't have fuses inline with them, so they would lock up, burn up the motor, and start smoking. Mine did this two years ago. I replaced it w/ a used one off Ebay and spliced in fuses. They are easily accessed and removed.
Colby Leonard
'84 911 Cabriolet
Gruppe B #005 Silver Bullet
Old 04-04-2004, 09:19 PM
Send a message via AIM to fintstone
This is what they look like. They are mounted behind the kickpanels.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-04-2004, 09:57 PM
robhamster's Avatar
thanks guys for the story and pictures. When you changed yours out, did you have to do both or could just one of them sieze?
1975 911S (old toy)
Old 04-05-2004, 04:11 PM
They are independent. They rarely both go bad at the same time. If both don't work, that usually means a fuse, relay or wiring is bad.
Old 04-05-2004, 04:27 PM
Jim Smolka's Avatar
Also, the footwell blowers do not come on unless the car is running and the engine fan is running too.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-05-2004, 05:42 PM
if a fuse blew, that's the first clue to a short lived motor. i replaced a fuse in one last week, and the motor ran and the armature started to glow bright orange.
206 637 4071
Old 04-05-2004, 06:14 PM
A Marchand fan before you
Por_sha911's Avatar
Next level of repair?
I replaced the 10a fuse on the driver's side back in February of this year. I haven't used the heater very much but I recently noticed the blower not running so I checked and sure enough the fuse is blown. When I put a new fuse in it blew imediately. Do I need to replace the entire blower or can it be repaired? Can I test the blower motor to see if that is the problem?
Joe
Old 09-28-2004, 08:36 PM
Sometimes cleaning up the fan a bit and adding a couple drops of oil to the motor shaft will fix this problem (dust and dirt causing drag)....but it usually means that you should start watching for a deal on a replacement. Sometimes when it is very humid or has rained a lot...you can get enough moisture in there to blow the fuse. It is ok after it dries out a bit.
Old 09-28-2004, 09:16 PM
Senior Member
What is a reasonable price for a fan like this? Believe that one or both of mine are going out.
Joe
2010 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 2010 Jaguar XF (fast touring car), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 09-28-2004, 10:14 PM
I have often seen them used here and on EBay for $40 to $60 each. The price goes up in the winter...closer to $100...I would snag any I saw under $40. You can always resell them and get your money back if not needed...and probably make a profit depending on timing.
Old 09-28-2004, 10:28 PM
i don't recommend using a used one. they fail with such regularity, it's a waste of time, and a potential fire hazard.
206 637 4071
Old 09-28-2004, 10:53 PM
Good point, but they are pricey.....if they have the fuses installed on the fans..like the '86, '87's...it seems that they shouldn't present any worse hazard than some of the other crazy electrical circuits...(ie the front condensor fan).... but you see a lot more Carreras than I do!
Old 09-28-2004, 11:10 PM
Senior Member
Guess its time to find some later model (86-89) model fans. Did not know that they had fuses on the assembly.
Thx,
Joe
Old 09-29-2004, 07:25 AM
SC-targa's Avatar
How much of a difference do these blowers make? My SC doesn't have them. I assume they make the heat output less dependant on engine RPM?
Jerry Kroeger
82 911SC targa
92 Miata
87 Suzuki GSXR-1100
1939 Ford Convertible Coupe
Old 09-29-2004, 08:33 AM
TMH TMH is offline
TMH's Avatar
I've got 2 blowers (and all accessory parts) pulled (working) out of an '87 Coupe, if anyone is interested in them for a reasonable price. They were removed from the track car (we don't need no stinkin' heater!)
Tom
Ain't life grand?
Old 09-29-2004, 08:39 AM
Senior Member
Tom,
Tried to PM you and its blocked. Please email me at:
joeaksaATattglobal.net (replace the AT with @)
Old 09-29-2004, 08:42 AM
Por_sha911's Avatar
Hey, Tom: did you say you have footwell blowers that work. Please e-mail or PM me if you are interested in selling one of them.
Joe
Old 10-01-2004, 10:07 AM
TMH TMH is offline
TMH's Avatar
Joe,
Looks like the other Joe is taking them both.
Sorry,
Tom
Ain't life grand?
Old 10-01-2004, 10:15 AM
Por_sha911's Avatar
The dog beat me to it when it was my question about the blowers to begin with! Oh well. Thanks
Joe
Old 10-01-2004, 10:23 AM
