-   -   911 idle? (http://forums.pelicanparts.com/porsche-911-technical-forum/157075-911-idle.html)
Scootr 04-05-2004 06:38 PM
911 idle?
Wondering if anyone knows what would cause my86 911 at start up to idle fine for a few moments then drop to almost a stall then idle back up to normal idle, sometimes it will go all the way and stall. It gets better when hot but still hesitate and sometimes, stall when hot. When accelerating seems to be fine, it only seems to do this between idle and 2000 rpm.
Lorenfb 04-05-2004 07:07 PM
Provide more info. Is everything stock and have you done anything to
the engine, e.g. mods?
Scootr 04-05-2004 07:11 PM
Engine is all stock 3.2
rzepko6194 04-05-2004 07:33 PM
Could be a vacuum leak. Check the hose connections and make sure the manifold nuts are tight.
Lorenfb 04-05-2004 11:04 PM
You have to start checking the basics:
1. temp sensor
2. fuel pressure
3. idle valve
4. idle switch
5. battery voltage when problem occurs (overcharging alternator)
Check out this web site (www.systemsc.com) on the Diagnostics page
under Poor Running.
scottb 04-06-2004 01:31 AM
Scootr:
I had very similar symptoms in my 84. I replaced the head temp sensor, the idle control valve, and the O2 sensor, but nothing helped. Then someone suggested that I have the mixture adjusted. I took the car to my pals at TRE and, BINGO, problem solved.
Try having the mixture checked before sinking a bunch of bucks into parts. Sometimes the simplest solutions are the best ones!
Good luck.
stlrj 04-06-2004 08:29 AM
Does it seem to be running rich by any detectable tailpipe odor?
Scootr 04-06-2004 02:49 PM
there is no dark smoke under acceleration, or does not seem to smell like it is running to rich.
stlrj 04-06-2004 06:45 PM
You might do a search on intake manifold vacuum leaks.
Lorenfb 04-06-2004 08:25 PM
Sounds like you want some more "darts thrown" at the problem versus
doing a little troubleshooting yourself. People have provided ideas, have
you checked them out?
rzepko6194 04-07-2004 11:57 AM
or maybe the problem is fixed and he's just out having fun! ;-)
I'm sure we'll hear about it one way or the other.
Scootr 04-07-2004 04:21 PM
No I just havent had time to check-it-out but as soon as I get a chance I am going to get busy, I really do appreciate all the information, Keep it comming.
