-   -   Power to windows problem (http://forums.pelicanparts.com/porsche-911-technical-forum/157393-power-windows-problem.html)
Mukilteo911 04-07-2004 02:33 PM
My power windows are not working. After searching the threads here and trying all I can think of, I need some electrical help.
I have used a probe and determined that power is not getting to any of the switches. I have replaced the fuse and swaped out the window relay.
At the fuse block, I grounded the probe and checked both sides of the fuse block for the window, it has power.
If the fuse gets and passes power and it's not a relay, where is the fault?
Can anyone help me with a valid test to find the short at the fuse block / relay area?
Mukilteo911 04-07-2004 10:48 PM
bump
doozer 04-07-2004 10:57 PM
Do you have power at the drivers side controll for the drivers side window? ( at the switch terminals)
Have you checked the multi-pin connector on the drivers side door ( what you would unplug if you were removing your door ) it is behind the panel in the floorboard.
targa80 04-08-2004 08:04 AM
What year and model car?
john walker's workshop 04-08-2004 08:06 AM
actually, that multi-pin connector is in the upper part of the door jamb, just below where the fender swoops back beside the windshield. they get unplugged sometimes.
Mukilteo911 04-08-2004 09:36 AM
its a 77,
I will check the multi pin connector.
doozer 04-08-2004 09:41 AM
Yea Jonny you are correct I meant to say while laying in the floorboard :)
