-   -   Trailing arm bushing question (http://forums.pelicanparts.com/porsche-911-technical-forum/157412-trailing-arm-bushing-question.html)
rs911t 04-07-2004 05:48 PM
I'm replacing these with the Weltmeister bushes. Do these need
lubrication? Seems like they're fixed and the lube goes around the bolt. Thanks.
Pat S 04-07-2004 08:28 PM
Correct, they should fit tight into the arm, I pressed mine in. Lube the inside hole and the bolt.
Pat
Jim Richards 04-07-2004 08:57 PM
Ditto.
